Page 5 of 7 FirstFirst ... 234567 LastLast
Results 41 to 50 of 61
  1. #41
    Join Date
    Apr 2011
    Posts
    948
    New Holland Boomer 50
    Default
    Quote Originally Posted by jimmyj View Post
    I like this thread. I can imagine all of us standing around at the OP's place with our coveralls on, bud or coffee in hand discussing how to move the old shed.
    "Well I remember back in 78 when ole Clem Smith had to move a shed just like this. Cept his shed had tin siding cuz Merle Barcklay used to keep chickens in it and the weasels was a chewin thru the wood siding."
    "Geez, I'd forgot about ole Merle, what happened to him after the wife moved out and he left for Tuscon..."
    5 hours later no work would have commenced!!!
    Sounds like a union crew.
  2. #42
    Silver Member mowin's Avatar
    Join Date
    Sep 2012
    Posts
    123
    upstate ny
    JD 3320
    Default Re: Ideas on how to move a shed...
    Going to check with a local guy auto repair guy and see what he would charge me...I could lift the back of the shed up as he winches it up.
    Thanks for the ideas. Got a few weeks befor I can get the shed. The guy I got it from wants the area to be frozen real good or dryer then it is now..
  3. #43
    Gold Member
    Join Date
    Aug 2010
    Posts
    326
    Norway
    Same Explorer 65, MF 135, MF 30, MF165, Volvo BM 55, Volvo BM 425, Volvo BM 2254, Terengmester skidder, Ford 3000, Fordson major, Derreng unknown model, IH B275, MAN 4R2, Gutbord sub compact.
    Make that a neighbor of mine did. He made a gizmo that he had on the three point hitch, backed the tractor in the shed lifted the shed with loader and the thing he had on three point hitch and drove home.
    wish I had a picture
  4. #44
    Super Member
    Join Date
    Jul 2009
    Posts
    8,571
    SW WA
    Kubota BX2360
    Quote Originally Posted by Tor Arne View Post
    Something like this?
    http://www.tractorbynet.com/forums/k...shed-move.html
    http://www.tractorbynet.com/forums/p...y-tractor.html
    Here's another shed move thread:
    http://www.tractorbynet.com/forums/p...-building.html
  5. #45
    Join Date
    Aug 2012
    Posts
    985
    Hartford, SD
    Kubota L3400F
    That isn't a bad idea if his tractor is big enough yet small enough to get inside.
    "Someone hold my beer and watch this..."
  6. #46
    Join Date
    Sep 2012
    Posts
    123
    upstate ny
    JD 3320
    That would work....... except.....This one has a floor...
    But that would be neat to see.
  7. #47
    Gold Member
    Join Date
    Aug 2010
    Posts
    326
    Norway
    More or less he lifted it by the roof trusses, no aditional struting/reinforsment. It was fun to see peoples faces hwen they meet him driving home the county road
  8. #48
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,867
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Many years ago my mom bought an 8x12 shed and had it set up with the back of the shed near the edge of their property line. Well, years after that, they moved from that house put it up for sale, leaving the shed as part of the sale. I was afraid that the end of it would be over the property line and cause a problem with a survey at the closing, so I drug it a couple feet to make sure all of the shed was on the their lot.
    That shed had two runners under it, which were just (2) 2x6's scabbed together. Both ends were cut at an angle on the bottom so it could be skidded for a short distance off and on the rollback for loading and unloading. This is the way a lot of sheds are built and delivered. Although, the really special purpose shed delivery trucks have lots of rollers on them instead a of a true flat bed wrecker style truck.
    I was able to drill 1/2" holes through the runners, run a 3/8" cable through them, and attach the cable to the tractor and drag it forward a couple feet. That was simple enough though.
    As for the OP's question, I would consider using the suggestion already made which is to use a bunch of round poles (4" diameter fence posts should work) and roll the shed the 500 yds. I would have to look REALLY close at the path to move it though, and would only do it this way if it was pretty level with no major transitions to cause problems, like a sharp grade at the end of a driveway or something.
    Most likely the shed he wants to move has runners underneath it. IF it does have runners, you would need poles that are wider than the runners are set apart. Figure out a good way to attach a cable or chain to it that spreads the load so it doesn't break the frame as it's pulled. Get enough of the poles and have a couple people on hand to keep "feeding" the poles from the rear to the front as the shed is pulled forward. And of course, go REALLY slow.
    By doing it this way, the tractor only has to pull the shed, not support one end of the shed AND pull it at the same time.
    Probably should do this on an early Sunday morning, when not many people are up yet, like a lot of house movers do sometimes. IF the path was not level, or has too much of a transition in places, then I would move it some other way.
    If the OP moves it on his own, I hope he makes a video of it so we can watch how it's done!!!!
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  9. #49
    Join Date
    Feb 2007
    Posts
    1,586
    easten Colorado
    JD 4020
    take two posts or square timbers, make steel loop bolt to the end of them, to hook a chain on the end of them, cut a spreader and attach it between the skid poles usually leave some clearance so if some thing catches it does not rip off the spreader, a spreader on the rear is good as well, jack up the shed, and slide it under and tow it home, I have slid small buildings this way a number of times,
    I even have a feed shed that is build on skids so one can pull it around,
    about half way down o the page shows a similar idea, Hudson Valley Vernacular Architecture picture from web page,
    Attached Thumbnails Attached Thumbnails Ideas on how to move a shed...-skid-jpg
  10. #50
    Join Date
    Dec 2001
    Posts
    240
    SE/Mid Michigan
    tc40, exmark lazer Z
    Default
    Would work and would be a lot of fun to watch. Might make that 500 buck purchase a little more costly
    Ideas on how to move a shed...-image-1670159025-jpg
Similar Threads
  1. How to move a large shed?
    By avc8130 in forum Projects
    Last Post: 01-10-2012, 10:31 AM
  2. move the shed
    By schmism in forum Projects
    Last Post: 05-31-2010, 12:10 AM
  3. Shed move
    By schmism in forum Trailers & Transportation
    Last Post: 05-30-2010, 02:44 AM
  4. Shed Move
    By ceh007 in forum Kubota Owning/Operating
    Last Post: 04-22-2009, 06:16 PM
  5. How do I move my shed ?
    By Madman_Mark in forum Owning/Operating
    Last Post: 11-22-2004, 11:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
