I'm curious what you used to make the swivel. I need to make one of those at some point.
Aaron Z
Aczlan here is some info for you. I recalled I had a box with some my experiment parts. The metal feeder tube and handles came from my old hose reels. I used the feeder tube as my pattern.
The PVC parts, all schedule 40, is what I used to make the feeder tube. Going left to right, we start at the Tee, 1 1/4 x 1 1/4 x 3/4 or1/2 threaded end. Inside the Tee I glued 2 small pieces, a piece from each side, of 1 1/4 pipe leaving the area of the Tee threaded part open. The pipe pictured at the bottom is the 1 1/4 pipe The ends of these pieces are chamfered to slide easily over the O rings. The 1 1/4 pipe fits loose on the 1" pipe just under the Tee. To the Tee threaded end you attach a hose fitting for connection to your water source.
The Tee end of the 1" pipe needs to have grooves cut into it for the O'rings . Two O'rings on each side of the Tee, with a water entry hole drilled and centered on the Tee. With the Orings installed in the grooves you slide the Tee over them and center it on the entry hole. As part of the build you have keep the Tee in position and keep it from sliding left or right. The 1" pipe with O'rings just rotates in the Tee.
Now for water exit to the hose I used a snap fitting. The snap fitting is the one with the dark pipe attached. The fitting has a threaded end either 3/4 or 1/2 inch. The threaded end is sealed. So you determine where you want the fitting on the 1" pipe, apply PVC cement and press it in place. It will snap on and grip the pipe tightly. After it dries you drill a hole in the threaded end and into the 1" pipe wall for water exit. Don't go too deep or you may ruin the job thus far. The dark pipe is threaded to the fitting and a threaded elbow is added at the top. To this elbow you attach the water hose fitting. Note the elbow shown has a slip end but you need a threaded end.
Clean any debris inside the pipe and then the 1" pipe is plugged or capped at the end. You have to sand the plug down so it fits inside the 1" pipe. In my case I will fill the plug and end of pipe with a product called Marine Tex found at boat supply houses. This product will set solid then you can drill it or tap it for a handle. I didn't do this on my utility model but will do it on my next model.
Now cutting the grooves. You have to use a table saw and a homemade jig to allow you to rotate the pipe as you cut the grooves. Can't remember how I did it. Just come up with a safe way to do it. O'rings, finding the right ones may require looking around the box stores. I used O'rings from a very old set I had. Looking in the supply houses I could not match the numbered O'ring shown on the white card. I did find a suitable one at Home Depot but did not write down the number. A 3/32 or ⅛ inch will work. Cut the groove so half the O'ring sits in the groove and the other half sits proud of the pipe. You need a tight fit between the O'ring and the small pieces inside the Tee. For my tube I cut the grooves So I had a diameter of 1 1/8".
Finally you need bearings for the reel to easily rotate. I struggled with ideas for bearings, couldn't find anything locally. Finally, for my utility model, I used some ball bearing rollers I had on hand. It works pretty good for a utility model. Rollers are shown on right side of 1" pipe.
When you get the tube finished pressure test for leaks before moving on. Hope all this is clear.
This all sounds difficult but it's rather easy to do.. Good luck if you want to give it a try.
