Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 59
  1. #11
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,620
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: DIY PTO Generator
    lotsa sources for heads.
    northern tools.. harbor freight.. etc. ebay has a ton of them.
    I've seenthe gearboxes at surplus shop...
  2. #12
    Silver Member Oldtink's Avatar
    Join Date
    Mar 2011
    Posts
    208
    NW.PA
    JD 3520
    I bent the H.wall SS pipe and 1/4" plate myself. It came from "electric generators direct.com. "
    And thanks. I really enjoyed building it and TIG welding the pipe. The frame is actually in 4 pieces.
  3. #13
    Join Date
    Mar 2002
    Posts
    52,620
    Central florida
    nice..
  4. #14
    Join Date
    Oct 2008
    Posts
    1,180
    Mid. Coast Maine
    7610 hst
    Too bad your not closer I have a 10 kw head with control box and pulleys I would give away,, Too many other projects going an I'll never get to this one,,
  5. #15
    Join Date
    Aug 2012
    Posts
    51
    Thousand islands
    1320 NH
    This is a DIY project that is still in progress.
    The mid pto is 2000 rpm and it seems to have plenty of throttle left for full load.
    BC164C - YouTube
  6. #16
    Join Date
    Jun 2011
    Posts
    71
    Enfield, CT
    Kubota B7100
    This is the belt driven PTO generator I put together. It is a 7kw military Onan. Yes it has open rotating pulleys as did much of the farm equipment I grew up around. It is being powered by a B7100 and ran 16 hours a day for 7 days. No belt slippage for the output we needed but we only ran it for heat, a few lights and misc electronics. The voltage was watched closely and once the rpm was set for 125 volts it was very steady. The parts minus the generator were about $200. Wide open throttle will run it at 540. With the PTO in high range the engine is running about 1/2 throttle.
    DIY PTO Generator-1104111448-jpg
  7. #17
    Platinum Member 3v0's Avatar
    Join Date
    Jan 2013
    Posts
    521
    Oklahoma Pan Handle, United States
    Kubota BX2200
    Why but a PTO driven generator when an engine driven portable on is no more expensive ? Thinking 7 or 8 KW range.
  8. #18
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    8,783
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Try searching Craigs List OFTEN.
    I picked up a barely used 12KW Winco for $600 and about a week later saw a 20KW for about $900.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  9. #19
    Super Member
    Join Date
    Apr 2004
    Posts
    6,489
    East Coast of Lake Huron
    Deere, several
    Quote Originally Posted by Dana Warner View Post
    There are some people that try to impress other folk with how smart, capable, fit and great warriors they are. By having all manner of hazards about them and be alive to tell the tale.
    I see a lazy cheapskate that is in denial.
    Set the speed to Frequency, not voltage. It's an AC machine, not DC.
  10. #20
    Join Date
    Jun 2011
    Posts
    71
    Enfield, CT
    Kubota B7100
    Say what you will but it works like a charm and does exactly what I need. You can throw money around to have all the shinny new stuff you want. When we were with out power for a week. There was no gasoline to be bought only siphoned out of the vehicles. Oh no that's not safe either. I have plenty of home heating oil, and a small tractor that did what I needed. No extra engine to maintain. Why would you really need 14k in an emergency which is what this was built for? Denial hahaha what a trip.
Similar Threads
  1. Fixed my 345 PTO bearing noise - DIY included
    By glader in forum John Deere Lawn & Garden
    Last Post: 12-02-2014, 10:45 PM
  2. 15kW PTO generator with PTO shaft and cart
    By sewerzuk in forum Private Party Ads
    Last Post: 10-16-2011, 09:05 PM
  3. DIY PTO Cable replace?
    By ctpres in forum Kubota Owning/Operating
    Last Post: 10-04-2009, 12:34 PM
  4. DIY JD 314 PTO
    By sos1 in forum Build-It Yourself
    Last Post: 06-06-2009, 09:53 PM
  5. What PTO speed on 1510D for PTO generator?
    By brotherjohn in forum Yanmar
    Last Post: 02-03-2006, 02:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
