Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,060
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Default Anyone modified a pull type, 3 bottom plow to 3 point?
    I tried finding a reasonably priced used 3 point 3 bottom plow for the fields on our 10 acres. Well a deal came up on a John Deere pull type hydraulic controlled depth/transport wheeled 3 bottom and I purchased it. The problem is on the size of fields most of the time will be spent getting turned around at the end of each furrow, here's the plowAnyone modified a pull type, 3 bottom plow to 3 point?-jd-plow-new-019-jpg The other option other than using it as is, or moddifying it would be to trade or sell and find a 3 point version,but time is running short.. what do you think??
  2. #2
    Join Date
    May 2003
    Posts
    720
    NE PA
    AC 5020, Gravely Com12, JD X300R, WH 16 Auto
    Default Re: Anyone modified a pull type, 3 bottom plow to 3 point?
    I converted an older rope trip JD 2 bottom many years ago, basically used the lift axle brackets for the 3pt lift arm bar, cut off the frame forward, moved the front frame piece and drilled holes to keep the structure of the frame, and welded a bracket for the top link. Welds must be Good no chicken poop, and the lift arm bar needs to be set correctly for side to side position so they pull right but it can and has been done.
  3. #3
    Gold Member
    Join Date
    May 2009
    Posts
    259
    Central Illinois
    several kinds and sizes
    I did an AC 2 bottom and have used it for 7 years.---cut the front beams down short as possible and remove axles levers (mine didnt have any,--someone stole them) ---then I added the 3-pt. adapter parts and got my plow! thanks; sonny 580
  4. #4
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,151
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    With Craigslist at your fingertips, I'd try a "want to trade" ad in the farm machinery. As many are getting back into "plowing days" someone might be looking for a decent pull type for behind a classic G, or something comparable, and willing to trade, or maybe a little boot. Depends on how bad one wants the other's plow..., LOL... Worth a shot..!!
  5. #5
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    1957 Ferguson 35, 1977? Yanmar 2200, 1963 Cub Cadet Original
    Your old plow looks to be in decent condition and some of the tractor clubs are having "plowing days" to teach the collectors how their tractors were used back in the day. So it might be very tradeable.
    If that option doesn't work then I'd find a plow like I wanted and measure it up and pay close attention to how it was built and go home and cut out the parts I needed and add to them to build what I wanted. That is easily done with old equipment, convert old into new.
    Like js said, no chicken poop welding as there will be lots of pressure on it.
    I guess I got lucky and bought a good heavy duty 3ph 2 bottom plow for 32.00. Guess it was my lucky day. Was at an auction and it was going cheap so I bought it. Don't use it...but if I ever need it....
    modify, adjust and improvise....a country boy can survive
  6. #6
    Join Date
    Oct 2012
    Posts
    2,060
    North Idaho
    Quote Originally Posted by DJ54 View Post
    Checked the local Craigs list - only two wanted ads both looking for 3 point versions so I think I will go ahead and try as is, if I can get it broke up some (the ground not the plow) then take the disc i got last year maybe get the field smoothed out, also have a 84" tiller ,but it needs gear work... always something ...
  7. #7
    Gold Member
    Join Date
    Jan 2007
    Posts
    316
    Looks to good to alter.
    Have worked bigger trailing machines on a lot less than 10 acreas.
  8. #8
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    sd, I'd be working on that tillar. Having a tillar is why I never use my bottom plow.
    I looked at my bottom plow yesterday after reading your post and it was simple constructed. Cutting out the portion you need to save and converting it to 3 point would not be that hard to do, just do it strong n solid.
  9. #9
    Join Date
    Oct 2012
    Posts
    2,060
    North Idaho
    Quote Originally Posted by R W View Post
    I think that's my problem, kind of hate to cut up , the only JD piece of equipment I own Anyone modified a pull type, 3 bottom plow to 3 point?-jd-plow-jpg
  10. #10
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,623
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    Hmm ive been watching this for three days now, and you aint got 'r done yet ?
Similar Threads
  1. Can a 1601D pull a 2-bottom plow?
    By queen of spades in forum Yanmar
    Last Post: 09-17-2008, 02:35 AM
  2. Replies: 16
    Last Post: 04-02-2008, 03:55 PM
  3. Will my 870 pull a 2 bottom plow?
    By Oleozz in forum John Deere Owning/Operating
    Last Post: 01-17-2006, 07:41 PM
  4. old two-bottom pull-type plow - modify/alter?
    By OldJD in forum Build-It Yourself
    Last Post: 04-18-2005, 08:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
