Results 1 to 10 of 10
  1. #1
    Join Date
    Dec 2012
    Posts
    50
    Surrey, UK
    1981 JD1640, 1973 Ford 3000
    Default Tractor mounted fence post driver ideas
    Here in the UK, we typically use split chestnut stakes (approx. 4-5 diameter and halved) and barbed wire or for fencing suitable for cattle and sheep. The posts are normally 5? or 6? and go 8-12 into the ground. Over the years I have put a lot of posts in the ground, just using a manual post rammer. Itç—´ hard work for sure, and the older you get, the harder the job gets. My former youthful energy seems to have got up and left me.
    I have been thinking about easier ways to push fence posts into the ground. Our needs and certainly our budget don't permit some of the fancy manufactured tractor mounted post ramming gear, as nice as it is.
    I don稚 have access to a 360 digger or a tractor that can push down with the bucket. Our Ford 3000 uses gravity to drop the FEL, it doesn't get much cheaper than free
    So I've been researching and thinking how I could make a tractor mounted device as cheaply as possible. I've seen some pretty ingenious ideas, but these have mostly been applied to larger, heavier machines with power down available on the FEL.
    Instead I wondered about have a 3 point mounted hydraulic cylinder that would use the tractor's own weight to push the post in, so working like a hydraulic jack really.
    Having recently been building a hydraulic splitter with a 10 tonne cylinder on it, I considered the cylinder could be put to a secondary use to save money. The stroke at 500mm (19? would be ideal.
    Has anyone tried something like this? Do you think it would have enough downward force? I am thinking of using such a tool fitted to our JD1640. I don't know how much it weighs? Must be at least 2-3 tonnes? Are the link arms man enough to lift the tractor?
    The ground round our way is predominantly clay, so pretty soft in the wetter seasons (that's all year round right now ) but goes pretty solid in the summer (if we ever get any).
    Your thoughts please gentlemen...
  2. #2
    Super Member
    Join Date
    Jul 2009
    Posts
    9,005
    SW WA
    Kubota BX2360
    Default Re: Tractor mounted fence post driver ideas
  3. #3
    Join Date
    Dec 2012
    Posts
    50
    Surrey, UK
    Cheers Bruce, I came across this one before. Not quite what I had in mind though, as this one still pounds the post. It certainly shakes the tractor around a good deal too. The FEL mounting provides good flexibility of positioning, but I only have single acting hydraulics on the Ford 3000's lift arms.
    I was considering a hydraulic downward push.
  4. #4
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    I haven't built wood fences for a while.
    If you're only doing a few hundred posts, just drill them, drop them in and tamp them by hand.
    The one-man handheld augers are very effective. Basically a lawnmower & flexible shaft, with a pole between the auger and cart to reduce torque.
    What we ended up doing was predrilling the post holes, perhaps 4" or so for a 5" or larger post.
    I remember Dad used to pound quite a few in with the front bucket & some weight (dual acting hydraulics).
    Eventually they got a rear mounted post pounder, but by that time I had already graduated HS, and I don't remember it much. I assume it uses a mix of weight and hydraulics. I'm not sure if it pounded or pushed, or both.
    Nonetheless, predrilling the holes helps reduce the power requirements, and keeps everything straight.
    Steel pile (sheet pile, posts, etc) is normally driven using a vibratory driver which is extremely effective. However, I'm not sure if a wood post would withstand the vibration stresses.
  5. #5
    Join Date
    Dec 2011
    Posts
    1,368
    Wisconsin
    New Holland TC33D w/supersteer and loader
    My neighbor has a old narrow front farmall that has a hydraulic post pounder on the front. One day he wanted me to help putting in a fence with wood posts. Some of the posts were about 8" dia, flat bottomed, and it was mid summer, hot and dry. I was thinking there was NO way that old thing was going to drive them posts. I was wrong, to heck with all that digging, tamping, ect......that thing amazed me!
    NH TC33D, Lorenz 5ft blower, KK 60" tiller, Rhino rear blade, Kubota RTV900, Stihl 170, 026, 029, 361, 460, FS85. Husqvarna 2100cd, 261, Speeco 25t splitter, Cub Cadet 982, Deere x744
  6. #6
    Super Member Robert_in_NY's Avatar
    Join Date
    Aug 2001
    Posts
    8,546
    Silver Creek, NY
    Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
    Around here we can usually find used post pounders for around $150. Nothing wrong with them, just old. We mount them in the middle of the tractor as it is easier in the vineyards to have attachments mounted there. The hardest part is adapting the mount to each tractor. Here is mine mounted on a Farmall 45A. Originally this pounder was mounted on a Ford 3910. I also had another pounder that was off a Ford 640 that came to me when I bought all the equipment from another farm. Sold it for $300. So if this style will work for you it may be an option to start looking at some vineyard areas in Europe and see what is available there used. If nothing else an auger would be a good option.
    As for your idea, if you have very soft ground you can push a thin post into the ground but around here you won't be able to do anything more then a steel t-post. A 4" round wood post wouldn't even sink very much at all and definitely not enough to hold itself up on its own.Tractor mounted fence post driver ideas-forumrunner_20120310_115731-pngTractor mounted fence post driver ideas-forumrunner_20120310_115650-png
    God must love stupid people; He made so many
  7. #7
    Platinum Member NS Gearhead's Avatar
    Join Date
    Jan 2013
    Posts
    986
    Nova Scotia, Canada
    Sportsman 570
    If your 3pt will lift, but not push down, why not make a pivot point so that when you do lift the arms the other end is powering down?
  8. #8
    Join Date
    Jun 2012
    Posts
    87
    Independence, OR
    2004 JD 2210
    You may not have down pressure hydraulics but why not load something heavy into the bucket and use the weight from that for down pressure?
  9. #9
    Join Date
    Dec 2010
    Posts
    67
    Canada Northern Ontario
    Bobcat ct230, 35 hp Massey Furgeson 3Cyl Diesel
    Hello
    Can you help me, I have never seen a post pounder, could it pound steel pipes, around here we have diamond driller, they sell there use rods cheap,
    would something like that attach to a 3 PT hitch?
    I would make my life easier if I could just pound the pipe in the ground to make a fence,
    what would something like that weight? I would like to know so I can calculate shipping
    thnx
  10. #10
    Gold Member 204saskman's Avatar
    Join Date
    Jun 2009
    Posts
    322
    Kelliher, Saskatchewan, Canada
    Montana 2844R Hst
    Just look on kijiji in ontario. Type in post pounder. They will hammer in steel posts just fine. They are worth a bit more up here in cqnada but are very common.
    Montna 2844R W/FEL with quick attach LDR 400hrs
    96" Home made Chain harrows
    Line ripper/trencher/ sub soiler
    Home built 10' sprayer
    72" Home built snow pusher
    72" HD landscape rake
    60" Farmking 2 stage snow blower
    55" Rototiller
    78" Bush hog disk harrow
    Quick hitch
    2002 kobelco SR35-2 mini excavator 3550 hrs
    24" tooth bucket
    16" tooth bucket
    44" clean up bucket
    Hydralic thumb
    Ripper tooth
Similar Threads
  1. Will my tractor handle a post driver?
    By ezking in forum Attachments
    Last Post: 11-08-2015, 11:23 PM
  2. front tractor mounted post pounder??
    By maplehillfrm in forum Build-It Yourself
    Last Post: 10-26-2013, 05:49 AM
  3. DIY Fence Post Driver
    By DIY Rob in forum Build-It Yourself
    Last Post: 08-24-2011, 07:25 PM
  4. Front-End Loader Converting FEL mounted post driver to 3PH
    By Eric_Phillips in forum Attachments
    Last Post: 05-10-2009, 11:07 PM
  5. Fence Post Driver Question
    By 317140 in forum John Deere Owning/Operating
    Last Post: 01-03-2007, 03:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
