Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Bronze Member ghenges's Avatar
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    Default Re: Steel bending
    Quote Originally Posted by kdlklm View Post
    I have got some rectangular tubing that I need to bend a tight radius. It is 1x2x.125 Rectangular tube. I need to bend four pieces that are 30 inches long. The image below shows two of the pieces as they will appear finished. Wondering what would be the best way to bend something like this. I would like to do it myself, I did phone some machine shops and they wanted a lot of money. Any suggestions would be appreciated.
    Attachment 310193
    Very tight radius you are attempting to bend. Won't say it's impossible, you'll need to experiment to see just how tight a radius you can accomplish.
    Bends like this are usually accomplished by mandrel bending.
    You can "approximate" the mandrel bending process at home by filling the tube to be bent with molten lead (melt down a car battery or two). Lead is way better than sand.
    The lead can be removed by simple heating the tubing.
    Cerrobend is better than lead, but costs $15.00 - $20.00 a pound.
    Make a jig on your shop press or rig a hydraulic cylinder to essentially emulate a press break. It's going to take substantial pressure to bend the tubing.
    Another method is enclosing the tube by welding the ends shut, on one end fit it with a 3/8" hex socket screw or pipe plug.
    Fill the tubing with water, screw in the plug and bend. The pipe can also be frozen to increase the internal pressure, being careful not to burst the tubing.
    Please let us know how you make out.
    "I know the end of humanity is near when my tractor comes with a place to store and plug in a cell phone, but no tool box" -- God's Country
  2. #12
    Join Date
    Dec 2000
    Posts
    207
    Saskatchewan, Canada
    Kubota BX1830
    Bending the tube was purely cosmetic, but I'm thinking that I'm going to lean more to cutting and then welding it. But you have given me some really good suggestions. I've attached two renderings of what the difference would be, I've just always been a little picky about how things look as well as how functional they are.
    It was 107 bend with a 1 inch radius. Really tight.
    Steel bending-cut-jpgSteel bending-bend-jpg
  3. #13
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    If weight is not a problem, 1"x2" flat bar stock would bend nicely to the radius you desire.
  4. #14
    Platinum Member GLyford's Avatar
    Join Date
    Feb 2009
    Posts
    957
    MA
    If you make 6 cuts over 2-1/2" (1/2" apart) each about 0.2" wide at the inside of the wedge (mark each at 1/8" and cut outside the marks with an 0.040 cutoff wheel will get you pretty close to that), you'll have a pretty close approximation...and you won't have to hold the metal in place like you would if you did a cut-and-flip.
  5. #15
    Join Date
    Mar 2013
    Posts
    111
    Port Barre,La
    yanmar gt14
    Sand workquite well in most cases, but if the piece to be bent is short enough I'v found that filling it with water and freezing solid works better tha sand without resulting in a concave area on the inside of bend.
  6. #16
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    In the civilized First World
    A couple
    Does it have to be rectangular tubing? If you can go with square tubing, this may be the ticket for you.
    Quickfab square tube elbows - steel elbow and aluminum elbow manufacturer - Quick Fab Products Ltd.
    Paraphrasing Douglas Adams - So long and thanks for all the bacon.
  7. #17
    Join Date
    Feb 2009
    Posts
    957
    MA
    He could just use two of those side by side...
Similar Threads
  1. Buying Advice Rocket Steel Buildings aka Centuria Steel Corp aka Aztec Steel, etc...
    By Vancouver Island Waterjet in forum Buying/Pricing/Comparisons
    Last Post: 03-02-2013, 10:23 AM
  2. My new bending toy
    By daedong in forum Related Topics
    Last Post: 06-30-2012, 09:04 PM
  3. Steel underpan, front bumper, Steel cage??
    By pharmvet in forum Ag Tractors & Machinery
    Last Post: 02-01-2010, 12:38 PM
  4. Bending the bucket
    By B7500 in forum Owning/Operating
    Last Post: 08-10-2002, 07:18 PM
  5. Bending steel back on a box scrapper
    By gmason in forum Parts/Repairs
    Last Post: 02-28-2002, 03:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
