Results 1 to 5 of 5
03-28-2013, 08:14 PM #1New Member
- Join Date
- Mar 2013
- Posts
- 13
- Location
- NC
- Tractor
- MF 240, MF 245
Putting QA on FEL
Found a bob-tach QA throug a friend at auto recycle yard. I will modify it to fit on my MF 232 loader. Problem is it has been sitting out for a while and the lock pins are bound to the sleeves. Does anyone have ideas for breaking loose. Hard to get direct hit with hammer, and have soaked with penetrating oil?
Thanks in advance
Jayme
03-28-2013, 08:19 PM #2Silver Member
- Join Date
- Apr 2011
- Posts
- 179
- Location
- Marysville, OH
- Tractor
- JD 4300
Torch
03-31-2013, 06:55 PM #3New Member
- Join Date
- Mar 2013
- Posts
- 13
- Location
- NC
- Tractor
- MF 240, MF 245
Re: Putting QA on FEL
Spent friday night lubricating and beating out lock pins. Spent sat. cutting excess steel off QA used a Stihl 400 cutoff saw and friend with plasma torch. Also cut bracket plates off old bucket for attach to bob-tack. Have a lot of grinder work to clean up cuts. Hit moving parts with wire wheel to clean up. Will keep posting updates and pics soon.
04-24-2013, 06:12 PM #4New Member
- Join Date
- Mar 2013
- Posts
- 13
- Location
- NC
- Tractor
- MF 240, MF 245
Finally got all excess steel cut off and grinded. Took mounting plates from old bucket and added to the QA. Haven't had time to work on much but making progress. Took bucket cylinders off loader to rebuild. Waiting for seal kits from dealer.
Have many other projects to work on
Here are pics of extra steel cut of and a rough build.
04-24-2013, 07:38 PM #5Platinum Member
- Join Date
- Mar 2010
- Posts
- 673
Thanks for posting this as I have been wanting to do this to a least one tractor. A good friend Remy works on this stuff. I am afraid he is to good of a wrench though as he keeps most of it running. Internet searchs have turned up the ,''Boxes" buy themselves and this is the way I may go.
Similar Threads
Front-End Loader Would I damage the FEL by putting ballast weight on one side of the bucket?
By rbtjr in forum AttachmentsReplies: 33Last Post: 10-06-2012, 01:08 AM -
Putting in T-Posts with the FEL/ Bucket
By Dave5264 in forum ProjectsReplies: 10Last Post: 08-08-2009, 12:23 PM -
Putting a FEL on a 5 year old BX2230
By HarleyScooter in forum Kubota Owning/OperatingReplies: 13Last Post: 07-26-2009, 06:54 PM -
Does anyone else have trouble wth FEL removing and putting back on with a toothbar
By dannydan3 in forum Kubota Owning/OperatingReplies: 17Last Post: 08-24-2006, 05:56 PM -
Putting the BX to use
By Hoosier_Daddy in forum Kubota Owning/OperatingReplies: 9Last Post: 08-12-2003, 09:04 PM
