Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Gold Member
    Join Date
    Nov 2006
    Posts
    264
    Clover SC
    Kubota L2800 4WD FEL
    Default Tightening post spacing for hign tension fence?
    I am adding to my current pasture. One of the lengths is 650' long. I will be putting the "H" style tension posts on each corneter of the run. I will be spacing my tposts at 20'. How many tension posts should be in that straight 650' run??
  2. #2
    Join Date
    Oct 2008
    Posts
    1,063
    Piedmont Triad, NC
    Didn't intend to have a Deere fleet - it just happened 310C, F915,102 & 5200
    Default Re: Tightening post spacing for hign tension fence?
    If it's a straight & level run, you only need posts to resist tension at each end. Any other posts merely maintain wire spacing and height. I place tension posts when ever the direction of the wire pull changes. either to the side or elevation change.
  3. #3
    Super Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    6,048
    Central Texas, Jarrell
    Kubota Grand L5030HSTC
    Agreed, I don't use any extra H posts unless really significant elevation change and at corners.
    Quote Originally Posted by hosspuller View Post
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  4. #4
    Platinum Member atgreene's Avatar
    Join Date
    Aug 2007
    Posts
    873
    Sebago, Maine
    2005 TB135 Excavator with Thumb, Quick Attach System, Ripper tooth, 3' Hydrauic Tilt Clean-up Bucket, Skeleton Bucket, 1986 Kubota 4150 with Loader and Quick Attach with Woods Forks, JD B, 1963 IH 504
    I likewise only use posts for spacing as needed. I have a couple 2500' runs with minimal posts at high points/low areas and spacers.
    2009 Kubota M7040, cab
    2005 Takeuchi 135 excavator
    1963 Oshkosh 4819
    2013 GMC 3500 6.0 w 9-2 Boss V Fisher poly Sander.
    IH 504, JD B, Ford 2n, Farmall cub, Gehl 1475 Round Baler, JD 640 rake, Vermeer 2500 Bale Wrapper, Zetor 185 Drum Mower, New Idea 217 manure Spreader, Kuhn 4 star tedder, Farmi 501 winch.
    Local 740 Portland ME
    20 Scottish Highland Beef Cattle, 3 Herefords, 3 Goats, 2 Alpacas, 2 Llama, 140+- layers, and lots of maple trees.
    Facebook: Phillip View Farm
  5. #5
    Elite Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Kubota 9540, RTV 900 and David Brown 885.
    Default
    I agree with everyone else.
  6. #6
    Gold Member
    Join Date
    Nov 2006
    Posts
    264
    Clover SC
    Thanks all. It is a straight level run. tposts at 20' spacing sound right? 4 runs of wire to hold 2 horses and a pony.
    Thanks
    Wade
  7. #7
    Join Date
    Dec 2010
    Posts
    4,028
    SW VA
    Default
    Quote Originally Posted by blackrat View Post
    Thanks
    Wade
    Are any of those going to be electric?
    20' spacing and 4 strands sounds ok if they are hot, but I know nothing about horses.
  8. #8
    Join Date
    Oct 2005
    Posts
    6,048
    Make 2 strands hot, ground the others...T posts are fine...
    Horses are funny...you can put one in the most smooth set of pens you ever saw and come out in the morning to see a gash on the horse.
    Also, I've seen people keep horses in pens with wire, loose boards, all sorts of sharp and dangerous things...and they never get hurt.
    When a cow gets into a jam, she'll stand there and slowly move her legs around to get out of a tangle or tight spot. Often, a horse will simply go crazy and run thru/over stuff that they know is there...but they got boogered for some reason. Net, the planned smooth wire fence will work for the horses UNLESS they get boogered just wrong, then it's good to have the smooth wire fence...barb wire just cuts them up ... doesn't particularly deter them when one has gone crazy.
    True story...had an uncle who was around and trained horses all his life...roping, cutting, reining, ranch work, colts, studs, mares...you name it. He got an older gelding (not unusual) to break and train...two months into the training he was behaving reasonable, easy to saddle, get on, getting a good rein on him. Training was done in an arena with sand, fence made of V net wire...the kind you can't climb...large cedar (very visible) posts with cedar post railing on top of wire between each post. Fence right at 6 feet high. Point is the fence was very well built and visible and horse knew it was there....hours of training spent in the arena.
    One day, uncle was taking horse in gentle figure eight pattern, loping. Horse came out of one loop, but failed to somehow change leads and enter the next loop, just "cold jawed" and ran straight at fence, completely unresponsive to the reins. Uncle perceived problem and threw his weight left then right in an attempt to throw horse off balance and regain control/sanity. Didn't happen in about 7 strides. Realizing fence impact was imminent, uncle loosened up in the saddle and went over the top rail as the horse hit the fence. Uncle got up and dusted himself off, looked around. Wire net was split top to bottom just like it had been cut with a knife. Horse laying there outside the arena, neck broken, dying. There is a reason there are the warning signs required anywhere there are equine events...it can be dangerous.
  9. #9
    Join Date
    Oct 2008
    Posts
    1,063
    Piedmont Triad, NC
    I've had horses in high tensile wire for 18 years no injury. I insulated every wire and caps on t-posts. With jumpers I can make every strand hot or any combination. It keeps the horses off the fence.
    OP are your horses fence trained? The idea is to train your horses to respect the fence. They should KNOW it bites and hurts and keep away from it.
  10. #10
    Super Member Wagtail's Avatar
    Join Date
    Jan 2013
    Posts
    6,153
    St Helens, Tasmania, Australia
    JD 4105 / JD D110
    God love'em, horses are an accident waiting to happen. If there's one old rusty nail hiding in a paddock one of them will be sure to step on it. If something spooks them, they're not hanging around to find out what it was = they're GONE! It's a survival instinct. And no horse is 100% "bomb proof", including my guys who are the most placid (I'll get out of the way of your tractor, Mate, once I'm done with this tuft of grass) horses I've ever encountered.
    Fence wise, I've simply run 5 strands (no barbed) through star pickets (metal Y shaped posts, may be the same thing as your T posts) ending in wood H posts. If electric is required in the future, I'll be able to run a stand-off line off of the star pickets. I have placed yellow plastic caps on ALL of the star pickets for visibility & to protect the horses from rubbing up against them. You do what you can to make it safe for them but you can't wrap them in cotton wool or bubblewrap.
Similar Threads
  1. Electric fence post spacing
    By Bfitzgerald3 in forum Projects
    Last Post: 03-19-2013, 12:27 AM
  2. Fence post spacing for box wire?
    By clovergamecock in forum Projects
    Last Post: 02-04-2009, 11:58 AM
  3. fence post spacing
    By TrueCountry in forum Projects
    Last Post: 12-12-2007, 05:07 AM
  4. tightening fence
    By Jerome in forum Projects
    Last Post: 06-04-2006, 08:29 AM
  5. Fence Post Spacing
    By DTCOOPER in forum Projects
    Last Post: 08-12-2005, 01:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
