IC Smoke
Long story short I dont heat my home with wood but I do heat the 30x36 garage. I have split wood prior with a splitting maul and decided I would start collecting parts here and there to build one. I started with a trailer axle that was laying around, then I found a I-beam after taking in some metal to the scrap yard. I think it was around $20 I had to pay (scrap price/ pound). Grabbed a pair of wheels/tires from the local trailer RV surplus store along with the lights and wiring. I cut down a old 100lb propane tank for the hyd tank. The hydraulic cylinder came off a tiling knife that a local excavator was parting out/scrapping. The 11hp Honda came off a old pressure washer that the pump went out on (rebuilt once already) so it was cheaper to buy a whole new machine.
The rest of the parts I had to order from Surplus Center and Northern tool. 16gpm hyd pump (2 stage), trailer hitch, pump/motor adapter plate. hyd hoses, one way valve, splitting wedge, trailer jack, and misc. fittings and such.
My whole idea behind building on with the trailer axle is my father in law burns wood as well but they live a hour away so I wanted one that would go 70mph down a Michigan Highway and those TSC small wheel ones woudlnt last one trip! I didnt intend it to be this big but it just happened lol. I still have to buy a sheet of diamond plate for the inside of the wheel wells, and around the front to keep the dirt off the motor/pump and tank.
Only downside is once it was together and I fired it up I quickly found out that the Hydraulic cylinder had a bad front seal but I paid $50 for it with no guarantee so I didnt sweat it too bad.
It only took a year to find the parts but its 98% done in the last photo. Yes the trailer jack is different... the first one wasn't quite up to the job! lol
I will post a photo of it finished with the diamond plate later on. Low priority at the moment.
Ian
Ian
