ATV Rope wick mount
   / ATV Rope wick mount #1
jwmorris
Spring is here and the weeds are in full force. After a day of spot spraying and a round of broadcast spraying weedmaster, I decided I needed a different method. After a little research I went with a rope wick applicator using round up to speed up the process and get other undesirable plants.
Looked at building the applicator as its pretty simple but they can be had cheap enough, so I just bought one. The mount on the other hand seemed a bit pricey at over $300. So I made this one that uses double split set collars to mount it to the factory brackets.
The 1/2" all thread in the center it to adjust the height.
   / ATV Rope wick mount #2
Were did you get the wick applicator and price if you don't mind? Nice job on the mount! Thanks.
Dave
Ordered it from menards. Its a green leaf product and cost $137. You could buy the parts to build it for $80 or less if you already had the drills and taps but figured my time was better spent on the mount.
   / ATV Rope wick mount #4
Thanks,that's not a bad price.
Dave
Well, went over 5 acres around the house, now the wait to see the results.
   / ATV Rope wick mount #6
I built my own mount. I control the up and down with the winch. I also use the same mount with wick removed and a plow point added to make my rows in my garden.Wick Plow 4.JPGWick Plow 5.JPGWick Plow1.JPGWick Plow3.JPG
What have tou found to be the best mix to use?
   / ATV Rope wick mount #8
My 6' wick holds about 2 gal of fluid. I buy generic roundup in 2.5 gal jugs. I normally pour it straight out of the jug into the wick pipe. I use the atv mounted wick mostly around the house and other small areas. When I'm done, I pour what is left in the pipe back into the jug it came out of. I normally almost fill the jug back up. When using the tractor mounted, 20' wick, I normally use a half roundup to half water ratio.
   / ATV Rope wick mount #10
I never tried it, but I don't see why it wouldn't
MURRAY PUSH MOWER (A58216)
MURRAY PUSH MOWER...
20 UTILITY TRAILER (A58216)
20 UTILITY TRAILER...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
1694 (A58375)
1694 (A58375)
