Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
  1. #11
    Silver Member BelarusBulldog's Avatar
    Join Date
    Aug 2011
    Posts
    135
    The ROCK! NL. Canada
    Belarus 562 / Bobcat CT122 / Kubota BX1860 / Honda HT4213
    Default Re: Dump trailer
    Can't wait to see the end results. Keep up the good work.
    Plowing, it's snow much fun!
  2. #12
    Silver Member FreshRouteFarm's Avatar
    Join Date
    Nov 2011
    Posts
    148
    Burtts Corner, New Brunswick Canada
    Case IH 485, David Brown 995
    Build looks good!
    Case IH 485
    David Brown 995
    John Deere 430W
    Polaris Ranger 400
  3. #13
    Silver Member Sfrankland's Avatar
    Join Date
    Jun 2012
    Posts
    187
    Newfoundland
    Mahindra 5010 Cab, Kubota U35-4
    Default
    Started welding up the deck. Almost got it all welded and ran out of wire. Will pick some up tomorrow and finish up the welding and adding some bracing. Hopefully it will be ready for paint by the weekend.
    Attached Thumbnails Attached Thumbnails Dump trailer-image-1848549038-jpg   Dump trailer-image-703561692-jpg
  4. #14
    Join Date
    Dec 2010
    Posts
    192
    Washington state and Ak
    5300 John deere,53 harry ferguson, ck20 kioti, 135 ferguson, 350jd dozer, k40 kubota excavator
    Looks good. Like where you put the axle. Should lift with enough angle to dump anything.
    This is a smaller unit I built. Has a larger one with hyd lift for a tractor but since sold. Have a couple of these and for around home it is great. You can see the pegs for the bed to sit on and when lifted with the bed off and the winch arm connected to the arch makes a good log getter.
    Attached Thumbnails Attached Thumbnails Dump trailer-p1000339-jpg   Dump trailer-p1000337-jpg
  5. #15
    Join Date
    Jun 2012
    Posts
    187
    Newfoundland
    Default
    Quote Originally Posted by plumbstraight View Post
    I really like your design. I wanted to build a log arch for my dad and this would be a very good way of building it. Thanks for posting.
  6. #16
    New Member
    Join Date
    Sep 2010
    Posts
    20
    Ford 3000
    [B][B]HOW MANY DO YOU WANT THEY ARE $ 750.00 EACH NO DELIVERYS
    PLEASE REPLY TO exharleyman@yahoo.com
  7. #17
    Join Date
    Jun 2012
    Posts
    187
    Newfoundland
    Default
    Quote Originally Posted by exharleyman View Post
    Not sure what your looking at selling but I think it is going to be very expensive to ship it to my neck if the woods.
  8. #18
    Join Date
    Jun 2012
    Posts
    187
    Newfoundland
    Managed to get the cylinder all plumbed in today. Got a small leak on the down stroke but other than that it works great.
    Homemade dump trailer - YouTube
  9. #19
    Join Date
    Jun 2012
    Posts
    187
    Newfoundland
    Default
    A little more done tonight. Hope to have it all done this weekend and maybe a coat of paint on it. Found out that the cylinder which has an aluminum body has a striped fitting. Need to take the cylinder apart and either add some material and re-tap or drill it out for the next size fitting.
    Attached Thumbnails Attached Thumbnails Dump trailer-image-1526951067-jpg   Dump trailer-image-3290066858-jpg   Dump trailer-image-3342697282-jpg
  10. #20
    Platinum Member NS Gearhead's Avatar
    Join Date
    Jan 2013
    Posts
    986
    Nova Scotia, Canada
    Sportsman 570
    Very nice little trailer! Check out my trailer build for tailgate ideas (if you need some)
Similar Threads
  1. Military trailer turned into a dump trailer?
    By Whitnel in forum Build-It Yourself
    Last Post: 08-04-2014, 10:27 PM
  2. car trailer to dump trailer, thoughts?
    By davedj1 in forum Build-It Yourself
    Last Post: 06-09-2011, 11:29 PM
  3. Convert landscape trailer to dump trailer
    By jeffah in forum Trailers & Transportation
    Last Post: 08-24-2010, 04:07 PM
  4. Convert trailer to dump trailer?
    By ids in forum Build-It Yourself
    Last Post: 01-10-2009, 09:51 PM
  5. dump trailer
    By avclay in forum Trailers & Transportation
    Last Post: 06-08-2004, 12:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
