cstamm81
Gold Member
- Joined
- Aug 10, 2009
- Messages
- 365
- Location
- Leesport, PA
- Tractor
- Kubota L5740, Mahindra 3016HST, Kubota F2880
So I am contemplating building my own splitter. I found these made by TimberDevil, the single and double vertical models: Timber Devil - Hydraulic Wood Splitter Manufacturer
The design intrigued me, I really like the waist level work height and the vertical ram design. I might try to replicate either the single or the double, but use an electric motor vs a gas engine.
I am thinking a 230V single phase electric motor with 3600 RPM output. Not sure if 5HP or I think the next step is 7.5 HP. I need to be able to run it from a normal house electrical panel. I would like to use a 22GPM 2 stage pump, which calls for 12HP, but I know gas to electric HP ratings are not the same.
Has anyone here built their own electric splitter with a larger than normal motor and pump? I want to have quick cycle times and have this be a serious splitter, nothing rinky dink here.
