Results 1 to 4 of 4
  1. #1
    Join Date
    Feb 2007
    Posts
    1,583
    easten Colorado
    JD 4020
    Default trencher back hoe rebuild
    I have a number of water lins to put in this summer, (at least a 1/2 mile) and maybe more. If I can do it with out a lot of jerry rigging and fighting things) THUS MY IDEA.
    I have a home built back hoe I have for sue on my 4020 large tractor, the tractor is more tractor than it should have for the back hoe,
    I have a Old Auburn trencher, at one time I made a creep drive on it, the tractor is to heavy for the drive, thus does not work well and gets stuck all the time. use on the 4020 tractor, (do not have the tractor it was designed for that would have been split and a creep transmission put in the tractor.
    I just got a gas John Deere 6 cylinder 404 engine from a old JD 105 combine, (similar to the engine in the 4010 and 4020 tractors,
    have a old 6600 combine for a axle or a old Massey Harris 82 combine axle as a possibility as well
    OK I would like to combine them in to a unit some what like a Ditch Witch trencher back hoe unit.
    something on the line of this vermeer unit http://www.purplewaveauction.com/a/2...pment/1101.JPG
    the engine has a adapter that looks like it can take a SAE bell housing,
    when I have thought about the idea in the past, I kinda had the idea of taking a old pick up and using the drive shaft to drive the trencher, through the transmission, (it was designed for about a 40 hp PTO tractor), (currently I do not have a clutch or transmission that fits the JD engine)
    the axle would be driven by a small Hydraulic motor (probably the one that I made the creeper drive out of,
    Questions
    would YOU, set the engine on in line like a car on the sub frame of the back hoe, and with trencher welded to the sub frame front, use a drive line and right angle gear box, (the right angle gear box is to light for the trencher unit and needs to be heavier, replaced),
    one could set engine side ways and belt drive trencher like the combines drove the transmission,
    or one could directly drive a good sized hydraulic pump and use a hydraulic motor on the trencher, (currently do not have pumps or motor)
    use a small belt drive pump on the creeper drive and to power the other hydraulics on the machine, 10/12 gallons a min would be more than enough.
    I would most like add a old truck steering axle under the back hoe end, and the creeper drive (combine axle on the trencher end).
    how would you set the trencher up to be driven?
    what other things have I over looked, (I want to redesigned the out riggers, and if I would combine the two units most like I would make a blade that would work as an out rigger and back fill tool,
    Comments or Ideas?
  2. #2
    Join Date
    May 2005
    Posts
    2,045
    N. E. Florida
    Default Re: trencher back hoe rebuild
    One option I see is mounting a sprocket on the trencher wheel and one on the tractor wheel. Instead of trying to push the tractor with trencher wheels drive the tractor. ?????
    Just a wild guess just from looking at the pics.
    You have a lot of parts and pieces and sure do have a lot of options.
    In the past I have cobbled different things together. Some were successful, others, not so much. That's why I hesitate these days.
    What is all that white stuff on the ground??????
  3. #3
    Join Date
    Oct 2010
    Posts
    743
    Just my opinions, they're free so take them for what they're worth
    I think a right angle gearbox would have to be quite tough to put up with the shock load. Not only that but I would imagine the shock load transferred to every other component in the power train would be high also
    That'd be my option, you have the option of changing ratio's quite easily by changing drive/driven sheave sizes should you find speed/power ratios are not what works well. Not only that but the belt acts as a shock absorber, granted belts that size are not cheap but are cheaper than a replacement gear box. The more directions you change thru gearboxes etc the more power you lose and the more components you add.
    I think you'd need a pretty good size pump motor $$$$$
    That's a good size amount to belt drive, doable but you'd probably need a dual belt at least, probably the best most versatile option unless there's some way you can direct drive the pump using a driveshaft .....IMHO.....Mike
  4. #4
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,620
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    Biggest advantage of belts is they dampen vibrations and allow slight misalignment.
Similar Threads
  1. Replies: 1
    Last Post: 04-28-2013, 08:35 AM
  2. Backhoe JD Hoe Subframe Part #LVA13818 "NEEDED" Cast Draw Bar Support!
    By magelan36 in forum Attachments
    Last Post: 04-27-2013, 05:55 PM
  3. Anybody have a Woods BH80-X hoe - with hydraulic thumb?
    By jim_wilson in forum Attachments
    Last Post: 04-27-2013, 07:02 AM
  4. Back Hoe Bucket Rebuild
    By Agent Blue in forum Customization
    Last Post: 08-19-2012, 12:36 AM
  5. Harbor Freight Back Hoe Trencher?
    By wmgeorge in forum Attachments
    Last Post: 02-04-2010, 01:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
