BukitCase
Elite Member
- Joined
- Feb 17, 2012
- Messages
- 2,748
- Location
- Albany OR
- Tractor
- Case 580B, Long 460, Allis-Chalmers 160
Good question - only thing I've seen is normal sized walk behinds. Whether you need a 2-cycle would depend on what type of bank you're wanting to mow. If it's vertical, trying to use a 4-cycle would likely run the engine out of oil (bad) - if the bank is less than maybe 30 degrees, you might get away with it.
Your comment about a USED mower probably negates this alternative
Sabre Samurai | Features
(Click on Ordering Info to see price)
But if that's not too expensive, it is easily adapted to nearly any angle with a bit of thought and some square tubing, etc... Steve
