looking for links on 3 phase power options
   / looking for links on 3 phase power options #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I just bought a few 3 phase tools to haul down to Mississippi. I have a 400 amp circuit breaker box with 3 or 4 220V lines, so I've got power.
But to get 3 phase will cost well north of $30K (I asked).
My most power hungry is the Powermatic 160 planar w/ a 5hp 3phase motor.
But I also bought a jointer, bandsaw, table saw, RAS, and sander so I figure I need to learn about 3 phase and the best way I can implement it.
The collection
Sander
RAS
Planar
Table saw
Jointer
Bandsaw
So I'm looking for some GOOD links on converters and DIY converters. I figure I'll want at least a 7.5HP system.
   / looking for links on 3 phase power options #2
Another option might be to get a military gen-set (MEP-002 for 5KW or MEP-003 for 10KW). Those put out 3 phase and would probbaly run under $5k and can be had for under $2k if you look hard enough.
Aaron Z
A 7.5HP RPC from American Rotary costs less than $800.
   / looking for links on 3 phase power options #4
   / looking for links on 3 phase power options #5
Here is a decent explanation
http://www.nojolt.com/how-to-build-a-rotary-phase-converter.shtml
You can also look for a frequency drive. I forget the hp ratio but you have to size considerably bigger for the motor you are trying to run. You can build a rotary for next to nothing if you have good sources. I remember going to my neighbors machine shop and watching him rope start a big motor lol. I think if I built one I would find a pony motor to start one.
   / looking for links on 3 phase power options #6
Variable frequency drives (VFD) are used a lot for phase conversion due to size and cost.
   / looking for links on 3 phase power options #7
If a static converter is used, you have about 2/3 of the motor ratings, if a rotary converter is used, then you have close to 100%,
I starting under load a rotary converter is needed, if no load a static can be used,
a commercial rotary converter is not much more than a shaft less motor with a static converter, to start it,
the static converter acts a start winding on the unused third phase of the motor, it is a set of capacitors and a short timer that charges the motor third winding to start it, (much as a capacitor start single phase motor does),
when the idler motor is running it acts like a rotary transformer, taking the single phase in two windings and then the rotation creates the third phase coming out the motor,
one can make a poor mans starter by taking a larger three phase motor (10 HP in your case wanting 7.5 HP, belt driving a small single phase motor to it for a starter, (one will have to check rotations and all), but apply power to the idler motor and the starter motor and once rotating disengage the starter motor from idler unit, (do not recommend, but once did see a picture old pull rope starter on the idler motor unit to get it rotating),
I would recommend a rotary converter for your shop.
there are plans on the net and if one wants to even what capacitors' are needed to make a static converter or starter,
   / looking for links on 3 phase power options #9
As an electrician who has installed VFDs for oil well sites where only single phase power was availble I would have to say they are the way to go... can not only give you a clean 3ph power source but also give you variable speed options. But it does draw the current. We often installed 70-100 amp 240v 1phase circuits to the VFDs to 3ph motors that pulled 30-40 amps also at 240v.
   / looking for links on 3 phase power options #10
Some VFD makers have drives for converting 1 to 3 phase. Danfoss offers these up to 30hp in 240v.
If drive maker doesn't offer a specific 1 to 3 phase drive then a rule of thumb is double you fla requirments.
1424 (A57192)
1424 (A57192)
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
1677 (A57192)
1677 (A57192)
