The JB weld? Oh it was just one of the treasures I found while tearing the place upside down looking for a drill bit. No doubt I'll find a use for it on this project too Fred.
P.S. what's a cultipacker? Is that like a rotary hoe or something?
View attachment 338289 View attachment 338290 View attachment 338291
Pictures from Google Image Search
Dragalong is neat! :thumbsup: How wide is it?
Yep, repair and installing fax machines. When I walked in to fix a machine, someone would say "the fax man is here". When I retired 12 years ago I became an ex fax man!Thanks for the pics - uncle google knows all.
Dragalong is almost 7' wide. It sure has done a good job in all its incarnations. It started off with just a chain bridle hooked to the towball (needed too much room to turn around but when you got stuck you could reverse up and do a running snatch to get it out) - then it got the teeth on the front - then it got the towing arm so it could be reversed (sort of - on flat smooth ground at least) - and now it's finally getting up/down wheels so it's going to be a pleasure to use now. Maybe a few cutouts in the front I beam will allow some more material thru to the "box" and I have thought about some method of "ramping" the rocks up into that box too so that they can all be dumped in one location.
Another incarnation maybe it turning into a towable scraper that can also be driven from a diesel motor & box & shortened diff (with dualies) out back and the motor can provided hydraulics and all the controls that need to run up front will be for clutch, throttle and the bucket hydraulics - I have been known to think up some crazy :confused2: stuff but I reckon if I win the time lotto, it could happen. Just a bit tidier shifting dirt over a distance.
What does Xfaxman mean - did you have something to do with fax machines?
I know what you mean "to think up some crazy :confused2: stuff" , just look at my avatar!
I am enjoying your thread, keep us posted on how it works in this incarnation. :thumbsup:
looks good. You might want to move the wheels further back. as they are it looks like they won't span much more than the skids would.
I made something similar to what you made, and I would like to move my wheels back some more.
homemade road grader
