-------------------- I was thinking if the winch goes through a pulley on the arms and then to the curl, then so when the winch is loose the bucket will sit flat on the ground and when you lift the winch it will curl the bucket (to an adjustable angle) and then lift and when you want to dump there will be a support arm that goes from the arm down to the frame to hold the arms while you release the winch to dump. I don't know if this make sense but it is just what I am thinking at the moment, if you don't think this arrangement will work please let me know.
