chad22
I built a home made excavator and have done lots of work with it and it's holding up just fine.
But the only thing I don't like about it is I have to crawl it or tow it into place. Crawling it is so slow and kind of limits it's use. I've also been removing brush with it so it would be nice to just drive right over to the burn pile with the brush and place the brush on the pile instead having to move it by hand later or to load a trailer with it.
I originally put an old Buick Regal rear end in it and was gonna eventually hook a hydraulic motor to it. But couldn't because of costs.
So I got to thinking. I have an old Sears Lawn tractor with the cast iron transaxle with hubs and those big lugged wheels that would work great on the excavator and will probably put mud tires on it for better traction.
I was planning on restoring the Sears lawn tractor. But really I'd get more use out of my excavator. It also has a good steering gear and everything.
If I use the transaxle I can just run a belt from the engine to the transaxle and use the clutch/brake pedal off the sears tractor as well to operate it with.
Everything would be right there to salvage parts from to make this excavator driveable.
If I make it driveable I can put a grapple on the excavator too and move firewood, some scrap metal etc.
I have the excavator here in Arkansas but the sears lawn tractor is 500 miles away in Kansas so can't really start on making it driveable yet.
But I can at least tear down and start redoing the frame to get it ready to mount the transaxle once I get the excavator back to Kansas in March or May.
I hate to re tear down the excavator. But sometimes it sits when there's things I could be doing with it if it was driveable.
So I know it'll be worth it to take that rear end out so I can put the transaxle in it's place to easily and cheaply make it driveable.
I could also then use the extra unused spool on my valve to work a blade in the front to push dirt around and level the ground with which could really come in handy.
Since I'm making it driveable I think I'll leave the twin engine on it instead of going smaller like I was planning.
When I get started I'll take some pics.
Chad
Chad
