Converting snowblower to 52" snowplow
   / Converting snowblower to 52" snowplow #1
Waldon52
Michigan , usa
John Deere
My name is Don Campbell and I live in Northern Michigan . I have visited this sight many times and enjoyed it very much. I decided today to register and show some of my garden tractor projects and workshop welding projects. 2 weeks ago I took my non working snowblower, cut off the front and welded plow brackets on the front. I built a light duty 18 ga. blade and it pivots by pulling a pin. I have used it four times in wet and fluffy snow and it works great. aduelset2.jpg
abigtire1.jpgaduelset1.jpgaheadlights.jpgasafetylight.jpgHere are a couple more pics of my walk behind 52" snowplow.
Thanks , it is perfect for pushing the snow in a windrow and not have to run the snowblower for just 2 inches of snow. I never liked running a snowblower for long periods of time with little or no snow in it. That is a lot of moving parts wearing out for nothing. What a easy project and I can't get over how well it works.
   / Converting snowblower to 52" snowplow #7
First I want to say WELCOME to TBN! You sure have and eye for detail and are very crafty. The three projects are very impressive. I also think you need to get some help for the addiction to green paint!! LOL
   / Converting snowblower to 52" snowplow #8
Welcome, and that great job on that!
   / Converting snowblower to 52" snowplow #9
very cool ! Iwondeer though -- why did you end up doing this? were you frustrated with alot of wet snow in your area ?
   / Converting snowblower to 52" snowplow #10
Will you then snowblower the windrow? Or is the plow heavy enough to push it? Will you have to add weight for the bigger storms?
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
1831 (A51247)
1831 (A51247)
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
