Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Dec 2013
    Posts
    3
    MA
    Wheelhorse 414-8
    Default Wheelhorse Cab
    Hey there all you tractor members,
    Has anyone built a tractor cab for a 400 series Wheelhorse tractor that has an Ark loader. If you have can you please send along some pictures of your creation. Also does anyone know if a "D" series cab will fit on a 400 series tractor.
    Thank you in advance to all of you for any assistance you may be able to provide to me.
    Rickeyrum
  2. #2
    New Member
    Join Date
    Oct 2013
    Posts
    3
    Mass
    Oliver
    Default Re: Wheelhorse Cab
    Funny we are thinking the same thing. Yesterday i started thinking about a cab for my 416H with kwik way loader. I'll probly start on my own build soon
  3. #3
    New Member
    Join Date
    Dec 2013
    Posts
    3
    MA
    Wheelhorse 414-8
    Stockblock,
    Thanks for replying to my post. I have been looking on the internet for ideas to build one. It seems there are many John Deere tractors with loaders and cabs but I haven't seen any for the Wheel Horse. I'm curious how you are going to build around the hydraulic post and the lifting cylinders. Let me know what you had in mind as our two front end loaders are similar to one another.
    Rickeyrum
  4. #4
    New Member
    Join Date
    Oct 2013
    Posts
    3
    Mass
    Oliver
    I'm thinking I'm going to replace the rear fenders with something of my own design ( probly section some trailer fenders) and build from there. It will be a bit narrow in the foot area but unfortunately there isn't a lot of options.
  5. #5
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,343
    Lancaster County, PA
    Kubota L3200, Ford 1210
    I found a picture of what sounds like your tractor on the net and cobbled up something quick for starters. Most of a frame can be made of 1" square tube. The doors could be hinged in the front for easier access. It could be fastened to the loader frame in the front - of course the loader would then need to be on for the cab. The pic shows some sort of frame for the counterweight, so if yours doesn't have that, you might be able to add something there. It would give you a little more room inside if you kept the width of the outside of the loader frame. Coming back off the bottom of that frame it would be simple to add framing for a bit more floor space.
    I built a cab for my tractor and it worked best for me to have a basic design and then get started. It was beyond my capabilities because there were too many curves, angles, etc for me to develop a complete dimensioned plan to work from.
    Sealing the front and side gaps can be as easy as picking up a piece of rubber roofing material to trim and fasten to the front frame. I did some sub-framing on mine and used the heavy clear plastic strips found on drive-through doors of refrigerated rooms. Wish you success with your build!
    Attached Thumbnails Attached Thumbnails Wheelhorse Cab-c-160-loader-22-jpg
  6. #6
    New Member
    Join Date
    Dec 2013
    Posts
    3
    MA
    Wheelhorse 414-8
    Chim,
    Thank you for finding me a picture of a tractor and the skelton frame for a cab.I like your ideas of mounting the frame to the loader sub frame and to the weight box as this is exactly what I have to work with on mine. My loader is a little bit different but nothing that can"t be worked around with some steel and plastic.
    Rickeyrum
  7. #7
    Join Date
    Sep 2013
    Posts
    162
    Farwell, MI
    Kubota & Wheel Horse
    One small alteration to the rough design pictured above is, the cross bar in front of the steering wheel won't allow the hood to open. By the time you move it back enough to clear the hood, the windshield will be getting mighty close to the steering wheel.
    NOT an end all to the project, just something to watch out for before you're too far into the build.
  8. #8
    Veteran Member skyhook's Avatar
    Join Date
    Mar 2013
    Posts
    1,919
    Canada Ontario
    1996 Kubota L4200 GSTC,(sold) 1994 JCB 210S 4x4x4
    Also, the tilt on the front windshield is too far inward, if you ask me.
    The top of it should come out a bit more as to not catch so much rain,
    not flat vertically, but almost is what i'd do.
  9. #9
    Member RAECOREP's Avatar
    Join Date
    Sep 2012
    Posts
    48
    Ramsey,MN
    kubota BX25
    You can do like I did, just grab some wood and start mocking up. That way it's easily changeable. I just kept adding/changing until I felt comfortable with design. Wood is cheap and easy work with. Once you get what you want, then make out of steel or not.
    Now Is The Time For All Good Men To Come To The Aid Of Their Country!
Similar Threads
  1. Wheelhorse
    By s78wingrider in forum Private Party Ads Archive
    Last Post: 06-02-2010, 08:44 AM
  2. Wheelhorse mowers
    By Lanse in forum General Lawn & Garden
    Last Post: 05-25-2008, 10:49 PM
  3. So many tractors!!! What about Wheelhorse?
    By mxlawyer in forum All Other Brands
    Last Post: 06-25-2005, 04:32 PM
  4. So many tractors!!! What about Wheelhorse
    By mxlawyer in forum Buying/Pricing/Comparisons
    Last Post: 06-25-2005, 03:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
