pbeamtn
After stalking this forum for some time and seeing what others have done, I decided to make a simple set of brush forks for my GC2410, and they are great! I have moved logs and brush much more easily than before. I wish I had done this last year.
I made the forks from 2"x 1/4" square tubing and 2" x 1/4" angle. The forks are 48" long and the width matches my bucket at 46". They are help onto the bucket by a lip in the front and ratchet straps on the back. Since they mount under the bucket, the ratchet straps are only under tension when the forks push down on something -- lifting pushes up on the back of the bucket. They are light enough that I can lift them onto the bucket or carefully "scoop" them up if on level ground. For my tractor, they are plenty strong, but a larger machine may need something heavier.
This is my first real welding project, and the welds are not pretty, but they are strong enough for my needs.
If you build a set yourself, be aware that it may make your tractor more "tippy." My backhoe seems to be a good balance even on the hills I have in East Tennessee. The ratchet straps can loosen -- I'm not sure why -- so they need to be checked occasionally. I also did not make vertical stops as part of the forks, so a large load can overflow the bucket and logs can potentially roll over the bucket and smash into the front of your tractor.
Here are some pics:
Here are some pics:
