Results 1 to 2 of 2
  1. #1
    Join Date
    Mar 2012
    Posts
    222
    new hartford, CT
    Kubota B7800
    Default Cover Plate to protect hydraulic lines
    On my B7800 the hydraulic lines and fittings run along the top and are exposed to falling objects.
    One line is already bent form the use of the prior owner.
    Lacking metal working skills, I fabricated 1" pt deck boards into a two plate cover with heavy iron
    angle supports. Very solid and sturdy.
    I removed the four original bracket bolts, added the lower plate and inserted 4 new bolts (1" longer)
    through the heavy angle irons,
    Then attached the front cover plate to help protect the hydraulic fittings, as well.
    Upcoming is a coat of kubota orange paint and a large Kubota sticker that is now on order.
    Cover Plate to protect hydraulic lines-p1030045.jpgCover Plate to protect hydraulic lines-p1030036.jpg
  2. #2
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,470
    Westminster, MD
    John Deere 4110
    Default Re: Cover Plate to protect hydraulic lines
    Looks great from here!
    Oh, and my my, that's quite the big hook you have there
    John Deere 4110HST
    FEL, MMM, Artillian 42" Forks, I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
Similar Threads
  1. Tonneau Cover - What do you use to protect it? Amor- all?
    By Scotty Dive in forum Rural Living
    Last Post: 10-30-2012, 12:57 PM
  2. hydraulic cover plate? 960 Ford
    By Patches in forum Ag Tractors & Machinery
    Last Post: 09-26-2009, 12:29 PM
  3. Plate for Hyd lines ??
    By DougM in forum Massey Ferguson Owning/Operating
    Last Post: 12-07-2007, 09:10 PM
  4. where is cover plate
    By geish in forum Kubota Owning/Operating
    Last Post: 03-04-2006, 05:17 PM
  5. Gasket for hydraulic cover plate on 3000
    By BobReeves in forum New Holland Owning/Operating
    Last Post: 12-27-2005, 10:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
