Just curious if it would be possible to convert a tractor into a dozer/crawler. I know you can do it with a garden tractor. Can you do it with a regular tractor and utilize the braking system on it?
I have often thought of doing this. Using the high sprocket system like the caterpiller system has now. I thought of building a frame with the idlers and rollers so that the tractor could be bolted into it. Just take the front axle, rear tires, put sprockets on the rear hubs, set the tractor into it and put the tracks over the sprockets. If you wanted a blade it would be designed into the subframe so as not to put a load on the tractor frame. Using master cylinders for braking with drums or disk brakes on the sprockets using one forward and one backward off the pitman arm it could be steered from the steering wheel with assist from differential braking from the pedals.
For me, the easy way out was to build tracks for all four tires. It drives normal, has better floatation, and doeesnt' add any weight to the axles as it is on each tire. I took 6inch channel iron cut it 12 inches long for the front and 8inch for the rear cutting them 16inches for the rears. Laid the channel out C down cut chain into three links and welded one link to one C and one to the other C with the link in the middle being the hinge. Welded some side plates to keep it centered on the tire and went about my business. They worked great.
To put on I torched holes in the end pieces so I could bolt them together. Rolled up on them, put a piece of rope though the spokes and under the first link went ahead rolling the track on. Deflated the tire, bolted it together and reinflated. The hardly squeaked and it would go anywhere I pointed it.
I thought if I broke one it would fly apart with the tire pressure against it so I did my best to break one until I did. It just broke one side and spread apart, no big deal, just took it off and rewelded. No damage. Saved me a lot of money in flats and was able to go with impunity, soft ground, briars, thorns, no problem.
