CDN Farm Boy
So finally got around to getting the garden in for this year. We started a new area behind the house, roughly a couple thousand square feet. A big step up since our last one was only a couple hundred.
Stripped the sod with the backhoe then did primary tillage 12" or so deep by digging and dumping back in the same spot. I don't have a plow or middle buster so this was the best option with what I have. I could then go over it with the walk behind tiller. Added 3 or 4" inches of mushroom compost and tilled that in.
We'd done our layout based on the tractor width with the tires making the paths and the space between the tracks being the beds. Looking to make my job easier, I went to the scrap heap to see what I could come up with:
Old carry-all frame that was lying in the scrap heap at Dad's farm for as long as I can remember that made its way here when he sold the farm.
The other part is a frame I'd welded up to go in the hitch of the truck to push an off-road buggy I'd been building back into the garage.
Set it together and a couple quick measurements ad it looks like it might work:
Some old brick lintel and 3/8 x 3 flat to make the scrapers:
Welded the scrapers to the sub frame then bolted it to the carry-all frame and I was ready for a test run
