Densleigh
Member
Hi,
I built one of these using scrap parts mainly. The only 'new' item was the auger spiral and two hoses.
The motor came from a reel mower (ransomes) was then attached to a small car gear box (robin reliant 3 wheeler!), locked in reverse to slow the motor speed and up the torque.
The output of gear box has a prop shaft flange plate to which I made a simple gimble assembly and in turn bolted auger to that.
tractor hydro supplies around 30 litres/ min.
Whole assembly was then made to fit onto a set of fork lift truck tines with forklift mast mounted on 3pt of tractor. use forklift to raise and lower as required.
The auger will bore a 8" dia hole about 1metre deep with only a few clearances for soil removal. Fortunately soil here in my part of UK is relatively soft and light with no rock content (only rubble but enough on that) Works well, not the fastest but does the job ok.
Gimble allows for getting hole vertical when on sloping / uneven ground or indeed boring a hole at an angle if required.
Tractor has several hydraulic ports so easy to use these as opposed to dedicated valves.
Sorry no pics at moment as on other major work.
