I have some shaft, about 3in dia I think. I remember dads old bigstick wood loader. The boom just swiveled on a solid shaft with a hole thru the middle. The hole was for the cable to run thru. I am not sure of the solid shaft size, but know it was probably 3in or larger. The boom turned by use of 2 hydraulic cylinders. There was a drum on the bottom of the boom which cable was wrapped around. The cyl would pull the cable and make the boom turn. We loaded some big logs with that loader. whitepines 4ft+ in dia and usually 12ft long. We also broke several of the turn cables. Later dad sold the bigstick and bought a kenimer loader. Boom mount was basicly the same, but the boom rotated with the use of a sprocket and chain. Broke a lot of #100 chains to. As I recall, neither of the loaders liked to rotate with a heavy load. I suspect that if i go the hydraulic motor and sprocket, I would probably look to do something similar as show in the link BHD provided. A double sprocket, and best i can count, looks to be 60 teeth on the bigger sprocket. Biggest sprocket on the surplus center site is 60tooth, #60 chain and only a single sprocket at that. Looking at the picture in the link, it appears to have two single sprockets spaced to accept a double chain, not a true double row sprocket. After looking at the pics, I think I have a plan to make the swivel. Got to check out some spare parts to see if what I have in mind will actually work so i wont comment on my plan. Maybe i will anyways. Someone might save me the trouble of trying what I am thinking
I think I can find a big truck rear axle. Cut the hubs off each side, but leave the axle tube long for trimming later. Weld the axle tubes together and run a big shaft thru the middle to connect the two hubs. I can use the flanges off the axles to weld to my large shaft. Connect my sprocket to the bottom hub and make the turning part down low. I can use the axle tube to weld in the frame and the hubs should turn freely. Mount knuckle boom to top hub. This should provide me with a top and bottom bearing support (4 bearings). Just dont know if I can make a sturdy enough mount to weld to the top hub that will hold the boom. I'll just have to go look at a truck axle before I am satisfied it might work.
