Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Platinum Member lzicc's Avatar
    Join Date
    Jul 2009
    Posts
    575
    Pittsburgh, Pa
    Kubota B2650
    Default Fuel Tank Storage
    I'm going to buy a 30 gallon drum tank for fuel storage for my tractor. What I am going to is put it in the truck and take it over the gas station to fill it up. When I bring it back home, I'll need to use my FEL to unload it. What could I put on the tank to be able to grab it with a chain? Also, will I get any flack from the gas station filling a tank like this while sitting in the back of my pickup?
    Fuel Tank Storage-tank-jpg
    Kubota B2650 HST - LA534, BH77, 60" BoxBlade
  2. #2
    Veteran Member kf4uda's Avatar
    Join Date
    Apr 2009
    Posts
    1,126
    Middle TN
    NH TD5030, 861 Ford Powermaster, 555A Ford Backhoe, S150x SnapperPro ZTR, Polaris Ranger XP800
    Default Re: Fuel Tank Storage
    This should work well for unloading with your FEL: Northern Industrial Drum Lifter | Drum Pullers, Rotators Stackers| Northern Tool + Equipment
    I would suggest checking your state laws as for filling and transporting. If your container meets state law then the gas station shouldn't be giving you any flack.
    Chris
  3. #3
    Join Date
    Sep 2012
    Posts
    1,208
    north shore MA.
    Default
    Quote Originally Posted by lzicc View Post
    .... Also, will I get any flack from the gas station filling a tank like this while sitting in the back of my truck?
    You might. Look at the pump for a sticker that says "aproved containers only" or simmilar.
    Dan H.
  4. #4
    Join Date
    Oct 2010
    Posts
    578
    WI
    '13 Yanmar Lx4100
    30 gallons nobody is going to care about, most transfer tanks in pickups are 50-90 gallons around here. A 30 gallon tank I would just roll like an oxygen tank, we do it with 55 gallon drums all the time.
  5. #5
    Join Date
    Dec 2012
    Posts
    1,199
    Ottawa, Ont
    Ariens
    or paint it yellow and put stickers on it "DIESEL ONLY" ... then strap it down in the bed ....
  6. #6
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,961
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    You shouldn't have any problems filling it in your truck. If you do, take your business to another station. Diesel is not going to flash like gasoline from static electricity so it is pretty safe to fill into an ungrounded tank.
    There are lots of ways to get it off your truck 1) put a strap around it at the top ring and lift it out. 2) If you have the bungs in place, you can tip it over and roll it off using an ATV loading ramp or 2x12 piece of lumber, 3) you could put it on a pallet and strap it securely and use forks on your FEL to lift it. 4) build a frame around it as one member did so you can attach a chain to the top lift arm and take it out with the FEL.
    Finally if you have a pocket full of money laying around, they do make an attachment for loading forks that is designed to lift barrels and it fastens and unfastens automatically. You just drive forward to position it around the barrel, lift and it closes, then to remove lower it a bit and back out.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  7. #7
    Join Date
    Jun 2008
    Posts
    10,961
    Bismarck Arkansas
    Quote Originally Posted by kf4uda View Post
    I don't think those would work on plastic tanks.
  8. #8
    Join Date
    Apr 2009
    Posts
    1,126
    Middle TN
    Quote Originally Posted by Gary Fowler View Post
    I agree that it would not work on plastic but that sure looks like a metal drum in the picture that he posted.
    Chris
  9. #9
    Gold Member
    Join Date
    Sep 2010
    Posts
    483
    Alabama
    Kubota B26, Kubota ZG222, Kubota BX2230 Kubota L45
    I just started using a 20 gallon plastic drum. I put a hose in the top with a valve on the end of the hose. lat it down in the bucket and load it in the truck then I lay it down in the bucket to unload it. and while I have it in the bucket I raise it up and gravity feed what I need in the tractor.
    Woody
  10. #10
    Join Date
    Jun 2008
    Posts
    1,892
    Arkansas!
    JD
    I keep my transfer tank on a pallet all the time.
    When its time to fill it I use my pallet forks and load it in the back of the truck. When I get home unload it and put it back where I keep it.
    I started buying diesel at Kroger. Using fuel points and buying when the price is lower it ends up being way cheaper than getting off road delivered for me.
Similar Threads
  1. Cleaning fuel storage tank?
    By MNBobcat in forum Oil, Fuel & Lubricants
    Last Post: 08-04-2011, 10:52 PM
  2. Fuel Storage Tank Reconditioning
    By kvancott in forum Oil, Fuel & Lubricants
    Last Post: 12-30-2009, 07:47 PM
  3. Fuel Storage Tank and Stand
    By GIJOE in forum Oil, Fuel & Lubricants
    Last Post: 07-26-2009, 08:48 PM
  4. Flushing fuel storage tank
    By The Dougster in forum Construction Equipment
    Last Post: 07-15-2009, 09:12 AM
  5. How do you clean a fuel storage tank?
    By Glowplug in forum Oil, Fuel & Lubricants
    Last Post: 08-15-2008, 04:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
