I installed a 16' gate across my driveway and an automatic gate opener. Works fine, except... As it hangs across the driveway, it is plumb and level. When in the fully open position, because of the slop in the tube gate hinge
the end drags the ground. The opener is strong enough to overcome it, but I'd like to change out the hinges or fix them so there is less slop. Since the bottom hinge is welded on, instead of clamped on, I'm thinking of cutting it off and welding on a barrel type hinge. Not sure where exactly to get one that fits correctly OR if the tubing is too thin to weld using a mig.
Anybody been able to easily resolve an issue like this?
