Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Join Date
    Feb 2011
    Posts
    925
    Oshkosh, WI
    Kioti NX6010HST Cab, Bobcat 773
    Default 3-point concrete placer?
    I am considering doing my driveway in concrete... but I've never done concrete before. I'd like to have the knowledge though. A good place to start seems to be a parking pad next to the barn.
    One idea I had is creating a tool for placing concrete that I would pull behind the tractor. Basically, it would be fixed for the width, and be a simple rectangular box. It would have wheels on each side which would ride on the 2x4 or 2x6 forms. The concrete truck would place the concrete in this box, which would then be pulled forward, essentially handling the entire "distributing concrete" and screeding process. The rear board could even simply move back and forth to act as a true screed if necessary.
    My feeling is this would allow 2 people plus the driver to essentially place the concrete, removing a ton of back-breaking work and leaving only the finishing process for manual labor.
    What am I missing here? This seems like it would work, but it also seems too simple and cheap that someone else would have done it. There are some minor logistics issues, in this design the concrete truck would have to drive next to the rig, and there would need to be enough space between the rear of the tractor and the box to allow room for pulling the wire mesh up. But it seems doable.
  2. #2
    Join Date
    Nov 2014
    Posts
    103
    Dresden On. Canada
    Int.2400a
    Default Re: 3-point concrete placer?
    I've done a few concrete placements and I'm considering the same projects. I doubt a good truck driver will have any problems placing concrete just where you need it. Watching an experienced finisher work with a power screed and a power trowel is an worthwhile education . You can probably rent this equipement to DIY---Trevor
  3. #3
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,406
    central Iowa
    JD 2720
    It sounds like a fun project for an experienced concrete guy, but only on a narrow, short sidewalk. That way you would be out maybe less than $500 just in case it failed. If it was my first time on something as wide as a parking pad, I'd volunteer to help the contractor I hired.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  4. #4
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    4,480
    Grants Pass, OR
    JD TLB 110
    I think that the weight of the box is going to cause the forms to fail. even a 2x4 or 2x6 placed on the ground will fall over when the weight of the box rolls over it.
    The standard way to do this is to use the chute the truck has on it to place the concrete in the forms. This way they do not have to withstand any weight, only sideways forces from the concrete.
    Set up the site so the truck can drive to within about 10' of any point in the concrete and you will be OK. You need to get a good book on DIY concrete, read it, and then watch someone do a pour. Come back when you have done that.
    Screwing up a concrete pour does not mean that you are out the cost of the concrete and the other materials. It will almost always harden into an undesirable shape that must be removed. The removal is very expensive. You are out a whole lot more.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  5. #5
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,671
    Nova Scotia, Canada
    Best be looking for experience on the end of the chute and a couple of guys with the screed board. If the concrete is properly the screed fellows have very little or no work to do.
    For a self levelling screed it gets difficult/expensive for a one time use. You'll need augers, vibratory system, rail/guide thingy and controls to operate it. Add in the concrete weight in the hopper and it gets substantial and expensive. Easier to spend the money on a crew. Probably cost a whole lot less than watching a segregated uneven pad set up while your trying to give it a trowel job and the next year watch the top spall off in large patches. The fellows that do concrete would be using a similar method to which you aspire if it worked easily and well.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  6. #6
    Platinum Member GLyford's Avatar
    Join Date
    Feb 2009
    Posts
    866
    MA
    The only time I have ever seen something along those lines is when they pour lanes for highways and bridges, and that's not a simple "hook it up to a tractor", that's a large powerful purpose built machine. Traditional concrete is work, yes, but it's not that bad. As long as you have at least one other person there besides the driver who has done any of it before you'll probably be OK. Completely exhausted, but OK.
    How wide and how long a driveway? Since they get poured in sections anayway, if you have more than just a couple of sections to do hire a full crew to do the first few, and only once you have seen the process and picked their brains and pushed the mud around yourself is when you should stop and rethink the process.
    In my opinion, there is enough going on that you can fuss with a new machine OR you can manage a concrete pour, you can't do both...and that's if you have done it. Learn to do it a new way as you do it, with an untested machine? Not gonna happen. You're going to end up with a machine-reinforced concrete block, and you still won't have a driveway at the end of it.
    Also, you're in frost country...proper finish is even more important if you want your driveway to last. Hiring a good crew might be worth it just to protect your investment in concrete.
  7. #7
    Super Star Member EddieWalker's Avatar
    Join Date
    May 2003
    Posts
    19,035
    Tyler, Texas
    Several, all used and abused.
    Concrete is one of those things that there are no shortcuts or ways to make it easier. It is VERY HEAVY, and unforgiving. It's simple in theory, but once you start working it, you realize that the timer is on and what you do once it's on the ground will dictate how it will look for all eternity. I've done a fair amount of work with it and I'm nowhere near close to being good at it. I've found that preparing the ground, setting the forms, digging out the footings and installing the rebar are what I can do well. If it's a small pour of just a yard or two, I can and will deal with spreading it and working it smooth. I've never done a job that was close to what the pro's do, but it's acceptable for those times when I do tackle it. For bigger jobs, I always hire a crew to spread and finish it. They make it look simple, but if you watch close, you will realize that the entire crew never stops moving and every single one of them is looking for and fixing things that you never even saw as a problem. It's one of those jobs that starts out hard, and then gets A LOT HARDER once the truck leaves.
    Eddie
  8. #8
    Join Date
    Feb 2007
    Posts
    1,583
    easten Colorado
    JD 4020
    some years ago, I made a spin screed, http://www.tractorbynet.com/forums/b...ml#post4066215 it makes working the concrete much easer,
    one can swing the chute and place the concrete fairly easily, the roller screed can help a lot, in seeing if it flat and if you have voids that need to be filled,
    I had a vibrating screed that I made using years ago out of lawn mower engine that would clamp on to two 2x materials, and made a coupler of out side handles with c clamps and a rope, it was heavy, and the motor unreliable so I sold it,
    also the vibrating screed would let mud work it way back up behind the screed, the roller screed has less of that problem,
  9. #9
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    8,790
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    OP -
    What are the dimensions of your driveway?
    I've got one that's about 10x20, I've got another that's about 100x20. About 40 years ago I had a truck pour about a 10 x 20 pad. I prepared everything myself and after the pour I finished it myself, no problem. I would not want to try a 100 x 20 myself.
    Size matters.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  10. #10
    Super Member /pine's Avatar
    Join Date
    Mar 2009
    Posts
    6,941
    Others have said about all that needs saying...but I have to say you answered your own question in the first post...
    (nothing derogatory in any way intended)
    My advice is to keep it as simple as possible and go with proven methods...
    Slash Pine
    blunt and succinct yet sincere I don't suffer fools or thin skinned neanderthals...in the immortal words of Popeye..."I yam what I yam"
Similar Threads
  1. Replies: 19
    Last Post: 01-26-2016, 07:38 AM
  2. Quick Hitches farmall 2 point fast hitch to 3 point adaptor arms
    By chuckyou in forum Attachments
    Last Post: 07-30-2013, 12:02 PM
  3. Replacing middle buster point with subsoiler point
    By queen of spades in forum Attachments
    Last Post: 10-03-2008, 10:26 AM
  4. Mixing concrete with a concrete mixer, 101
    By wroughtn_harv in forum Projects
    Last Post: 08-25-2005, 10:34 AM
  5. Three point concrete mixer
    By KiotiDK35 in forum Attachments
    Last Post: 10-05-2003, 05:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
