LD1
Epic Contributor
think I am gonna make one to install cabling and invisible dog fence. Plan to start this evening and will post pictures, but I have this idea in my head and though I would ask opinions and thoughts if there is anything to improve. Cant really draw out what I want very well so I will describe and hope you get the visual.
Basically picture a subsoiler with the bottom removed. Just the cross/3ph mount. Now on the bottom, I will weld a 4" x 6" or so plate with the front angled up. Kinda like a snow plow skid shoe. This will control the depth.
Now off the bottom of that, at a 45" angle as looking from the back of the tractor, I will weld a wedge made of 2 1/4" plates. And will be approx 1" wide at the back. On the sharp "business" end, it will be angled as well to dig in. So picture a subsoiler, but where it makes the bend or hook forward, lay that over on a 45* angle.
On the back, I will run pipe down the backbone , follow the wedge/knife, and then 90* backwards into the trench. And will mount a spool of wire up top somewhere.
The idea of laying the business end over to 45* angle is to kinda slice under the sod and lay the wire in place, instead of a vertical trench where it would be more likely for the wire to not stay in the bottom.
Thoughts?
Thoughts?
