sniper695
Member
I just ordered an underground fence for my dogs, I want to make a cable trencher for my CUT I was thing about making it an attachment for my rear blade. I have a piece of nice steel, about 4 by 16, at least 1/4 thick, my plan is to cut it so it has a hooked blade in front to help pull it underground, then a few pieces of angle iron to attach it to the rear blade, with a piece of tubing to run the wire through, are there any obvious flaws with this approach.
I want to attach to rear blade for simplicity, I don't need to setup the whole 3pt system and so I can use it as a weight to make sure blade stays in the ground. I have about 1000ft to run about 1.5 acres.
