Another ballast box 1000lbs
   / Another ballast box 1000lbs #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
Finished off a quick and dirty ballast box today. Plywood form, rebar, and 1000lbs of concrete Quickrete. Used a 3pth tow bar for lift pins and welded up some angle iron I had laying around for the top link.
4inch PVC with a drain hole in the bottom for long handled tools. 2" square tube hitch receiver.
I also used a plastic chainsaw bar cover for a scabbard form. Then I threw together a box on top to hold stuff.
   / Another ballast box 1000lbs #3
And when you lower the 3pth you know the tractor will stay where you leave it....The saw scabbard is a great idea as well
   / Another ballast box 1000lbs #5
luke, do you have your tires loaded as well?
I like the what you have done there.
thanks,
dave
Yes, tires loaded with calcium. But when using my tree puller or my freaking heavy, 900lbs grapple, I need all that weight! I also have a 600lbs box but that wasn't enough.
   / Another ballast box 1000lbs #7
Shovel holder- check scabbard- check hitch- check tool tray- check only the beer cooler is missing. Probably intentionally!
   / Another ballast box 1000lbs #8
That is very nice I like the box on top too. The saw scabbard is genius so that give me more ideas....
   / Another ballast box 1000lbs #9
I'll give you $350 for it:laughing:
Look's nice Luke, and some smart features:thumbsup:
Ha. Ha. Not a bite at $250 on CL. :confused3: So be it.
2009 Ford E-450 Super Duty Ambulance (A55852)
2009 Ford E-450...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
204158 (A57193)
204158 (A57193)
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
