Free Standing Treehouse
   / Free Standing Treehouse #1
buggyman1
Kentucky
Kubota B2150Hst
I promised my little helper i'd build her a treehouse after I finished the trailer. I got started on it a couple of days ago. I'm not using any plans, just gonna kinda wing it. I have a pretty good idea in my head how it's going to look, so that's our starting point. The main frame supports are 20' 6x6's set four feet in the ground. I got my post-hole digger stuck on a root, four feet deep, on one of the holes, I had to unhook it from the tractor and put my backhoe on to dig it out, fun stuff. I used five 80lb bags of concrete on each hole except the stubborn one, it took 12. Here's a couple of pics of our progress so far.
   / Free Standing Treehouse #2
Looking good.
   / Free Standing Treehouse #3
It may have been better on the pocket book to just reverse turn the PTO shaft to un-screw the auger from the root. If the auger isn't stuck hard, you may be able to turn the auger shaft with a large pipe wrench but it is easier to turn the PTO shaft although you have to make a lot more rounds. The few times that we have had a stuck auger, just a couple of rotations of the auger enabled the tractor to lift it out.
   / Free Standing Treehouse #4
Some tractors may not let you turn the PTO shaft and might require unhooking the shaft from the tractor.
   / Free Standing Treehouse #6
Looking forward to following your progress!!!!
   / Free Standing Treehouse #7
Looks neat and high. Could you also use it as a deer stand?
MoKelly
Double reason to build. Go up there to hunt while the little one plays with no sound toys
Tried that with a 36" pipe wrench, no luck. You can turn my PTO backwards most of the time, it was stuck good.
