Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
  1. #1
    Join Date
    Oct 2012
    Posts
    67
    Winnipeg, Manitoba, Canada
    Homemade
    Default radial arm saw plasma cutter
    hey, i'm half way though this plasma table project and would be interested to know what everyone thinks about it and if you guys have any ideas or input. thanks
    https://youtu.be/vxoFFD6_5xc
  2. #2
    Veteran Member Industrial Toys's Avatar
    Join Date
    Feb 2008
    Posts
    1,466
    Ontario Canada
    Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule
    Default Re: radial arm saw plasma cutter
    My first thought was, how awesome. Then I started to think about the advantages and could not think of too many. It's not hard to grab a straight edge and run your torch along it. It would be just another large piece of seldom used equipment in my shop. I really don't use my plasma much. A CNC table would be sweet, buty probably not used much either. Probably more for friends.
  3. #3
    Elite Member dragoneggs's Avatar
    Join Date
    Jun 2013
    Posts
    3,297
    Seabeck, Washington
    Kubota BX-25D, Z122RKW-42, and JD circa 1990 Lawn Tractor
    Interesting... I do have an old Craftsman 10in radial arm saw and drawer stand sitting around taking space. Definitely a poor man's unit but for bunches of consistent straight cuts I suppose it could useful. Worse case it is a little used accessory to a cutting table. I will follow along. Good luck!
  4. #4
    Join Date
    Oct 2012
    Posts
    67
    Homemade
    Yeah i think like you say either way ill have a little cutting table
  5. #5
    Platinum Member Big Barn's Avatar
    Join Date
    Aug 2013
    Posts
    790
    Victoria, B C
    More than 40 over the years. Ten at any one time. Mostly Ford and New Holland
    Default
    Quote Originally Posted by Industrial Toys View Post
    This is my thinking exactly. BuckitCase Steve mentioned this earlier and I had it on my to do list.
    The more I thought about it, the less enamored I was with the idea. (Sorry, Shiny Steve) Did a major shop clean up last week and well...this is where it now resides
    -image-2701097552-jpg
    -image-695265188-jpg Terry
  6. #6
    Gold Member farm boy00's Avatar
    Join Date
    Jul 2014
    Posts
    451
    byron center mi.
    allis chalmers wd45 farm king 990 and a duzen others
    Default
    Quote Originally Posted by Rednic79 View Post
    Video Link: https://youtu.be/vxoFFD6_5xc
    I love it. Seems really smart for a small guy. We don't have a plasma. Traded ours off years ago for truck work.
    It could be made to take any tool from a plasma to a grinder welder. The sky is the limit
    Men in denim built this country, men in suits destroyed it
  7. #7
    Join Date
    Oct 2012
    Posts
    67
    Homemade
    Quote Originally Posted by farm boy00 View Post
    yeah i thought it was kinda like a extra hand, i see myself using to do repeatable angle cuts. i do custom furniture work and often need that kinda thing
  8. #8
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,118
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    would replace the threaded rod and the battery operated drill. with a smooth rod. and then find some sort of handle to lock things down in place. perhaps 2 plates of metal. turned into a kinda of a vise or something to lock unit in position. and then when you want to make 90 degree cuts undo it. so you are completely in control of how fast you are cutting by hand.
    that threaded rod / battery operated drill = good for ripping stuff down kinda like a table saw when you rip plywood and boards down. and allows you to lock things in place. but you are more needing just the "lock" and then a free form slide without a motor to move things back and forth.
    might suggest pulling the grating out. and put some rollers down. for longer pieces of metal. and then when cutting shorter pieces of metal toss the grate back on top, and use a couple thumb screws /bolts to hold grating in place.
    Ryan
  9. #9
    Epic Contributor MossRoad's Avatar
    Join Date
    Aug 2001
    Posts
    26,549
    South Bend, Indiana (near)
    Power Trac PT425 2001 Model Year
    Since radial arm saws have been replaced by power compound angle miter boxes, they are pretty much giving them away, so good use for a set of legs and a table. As you mentioned having to do lots of repetitive straight cuts, seems like a good use. Set up a jig to make the same cut over and over again.
    How do you plan to make it trigger without you having to use your hand? A foot pedal might be nice. That would leave both hands free and not too awkward as it is now.
    MossRoad
    Click On My Little Tractor
    To See Pictures And Videos
    Of It In Action!!!
  10. #10
    Join Date
    Jun 2013
    Posts
    3,297
    Seabeck, Washington
    Quote Originally Posted by MossRoad View Post
    Definitely a foot pedal is in Rednic's future.
Similar Threads
  1. Longevity 62i plasma cutter on CNC Plasma table
    By blueriver in forum Welding
    Last Post: 01-20-2015, 07:52 AM
  2. Plasma cutter
    By ENG18LT in forum Welding
    Last Post: 03-15-2012, 04:41 PM
  3. New plasma cutter
    By crazyal in forum Welding
    Last Post: 11-25-2010, 07:09 PM
  4. building a radial arm saw
    By Kendrick in forum Rural Living
    Last Post: 10-12-2008, 10:46 AM
  5. Anyone have a plasma cutter?
    By davesisk in forum Build-It Yourself
    Last Post: 09-12-2008, 08:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
