Here you go:
Home made concrete, steel and lead wheel weights, 260 lbs for the right, 240 lbs for the left, total of 500 lbs (in addition to loaded rear tires):
Box blade rear weight block plus Rachet Rake holder, 410 lbs for the block and 110 lbs for the RR, total of 520 lbs at the rear of my box blade:
FEL torque tube weights. 4" 1/4" steel tube 18" long with 4"x4" 1/4" plate on one end, then 2" steel rod welded to plate, then filled with concrete. Total weight, around 40 lbs, total of 80 lbs for two of them:
Front end weights, total weight around 180 lbs:
The standard concrete filled barrel as a rear
ballast weight, around 750-900 lbs +/-, now replaced with my box blade with rear weight block +1200 lbs:
Good luck!
