Assembling Harbor Freight 1720lb trailer
   / Assembling Harbor Freight 1720lb trailer #1
Garandman
Elite Member
Mount Sunapee NH / Dorchester, MA
Kubota L3200 HST
Please don't clutter up this thread with "I bought an xyz for $$$ and it's better" comments. These kits are not for everyone but can be a great value.
I needed a small trailer to haul lumber, trash, bring snowmobiles in for service, etc. Didn't want to spend much and needed enough length for a snow machine so settled on the HF 1,720 lb trailer kit. The folding model is more popular but I have room to store this and like the higher capacity. It has 12" steel wheels. Paid $279.
One caveat: this kit comes with a certificate of origin. Some states require a state inspection of kits in order to be registered or titled, which would add a cost that might not be worthwhile.
The kit comes in two boxes which weigh a total of around 200 lbs. The HF guys will help you load it in your car. It fit easily in the back of an Outback wagon. One box contains the wheels and small parts: the other contains the frame members and axle and is much heavier.
   / Assembling Harbor Freight 1720lb trailer #2
Sounds like a pretty good deal. It shows up as $349, which is still a good price.
   / Assembling Harbor Freight 1720lb trailer #3
Hello,
I bought the same kit probably close to 10 years ago. It has been a great trailer. I put 5/4 x 6" pressure treated boards on for the floor. Used metal cutting screws to screw them to the frame members.......drilled a pilot hole for each screw as I went. The one thing I did do that I'm sure most people don't do is that after it was all bolted together and squared up, I welded all the joints. That way the frame is solid and can never shift or move !!! I also bolted on a bunch of d-rings along the sides, front and end for tie down places. Also, I added a few more side lights. The only problem that I have now is that I just bought a XUV 550 Gator and I need a bigger trailer....oh well !!!!!!
MFWD
Here is the box with the frame:
And the wheels and small parts and fasteners.
   / Assembling Harbor Freight 1720lb trailer #5
One thing that might be worth checking is the wheel bearings for grease, cleanliness and proper preload. You just never know what you have considering the source.
I was going to get to that. The bearings are packed in a clear preservative, NOT Bearing Grease! The instructions tell you to clean and pack them, but not all take heed.
The front bearing comes right out. I then put the hub in the middle of a wheel to hold it and used a large socket and extension and knocked the rear bearing and seal out the bottom of the hub. Cleaned the excess preservative grease off with Citrus Degreaser and then use brake part cleaner to thoroughly clean the hub and bearings. I packed them by hand while wearing gloves, then cleaned to gloves with some paper towels and brake cleaner to reuse them.
The bearing is 30205 Taper Wheel Bearings, 25mm i.d. x 52mm o. d. x 16.25mm thick. Local parts stores may or may not have them.
The bearing seal is a 52 x 30 x 10.
Some people switch to 1" hubs. They fit the axles (25mm is 0.984") and allow you to use readily available bearings, seals, and caps.
This trailer is assembled as two 4'x4' square sections with a yoke in front. You begin by building the front section (which has a cross member), then the yoke, then the rear section, then bolt the two sections together. You add the supports for the springs and axle, then put on the wheels and hubs and wire it up. It takes most people 4-8 hours.
I used a steel carpenter's square to keep the sections square and that was easy. Also put a socket extension on a cordless drill to run in the nuts.
   / Assembling Harbor Freight 1720lb trailer #8
Neighbors Brother bought one of those several years ago here in Oregon , since No Sales tax , ( They live in California ) . They assembled it here , ( Using My tools :confused3: ) and Used it to Haul the 4 wheeler they also purchased here , back home . Neighbor has said they have been using the heck out of it around their new place with clean up , etc... and it is still going strong .
I did pack the bearings for them and greased it up , Was not comfortable letting them use my Lincoln Air gun :D !!
Fred H
So i have the frame assembled and hubs on. The tires came with 30 psi and max load capacity is at 80 psi so be sure to air them up.
When you knock out the rear bearing seal, be sure to look out for the grease fittings on the back of the hub: I broke them. They were brass: I replaced them with steel ones (6mm, straight).
Wiring it up this morning. I'm adding a wire ground as the powder coating and bolted assembly makes frame grounding spotty.
I'm going to solder and shrink tube everything, but I think I'll use spade connectors for the lights so if I want to switch to LED lights it will be easier. For the amount I'll use it I kept the stock lamps for now.
   / Assembling Harbor Freight 1720lb trailer #10
I bought one of those HaulMaster trailers last spring. This is the top-of-the-line HF
trailer, and I wanted another trailer smaller than my big dually.
Anyway, I welded mine all up, added a couple of crossmembers and a steel deck. LEDs,
too.
The hardest part: grinding off the powder coating for all the welds.
Note that this trailer shares some parts with the folding, lighter-duty trailer, and so the
middle side joints are weak and should be welded. If you use plywood for the deck,
that is structural, and holds it all together. I use galvanized sheet metal.
The bias-ply trailer tires need to run at at least 75psi (rated 80psi) not to heat up.
Not only are these Chinese units weak on bearing grease, the hub nuts are often
pre-set WAY too tight.
STORAGE FEES (A59575)
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
Forklift (A59228)
Forklift (A59228)
2000 INTERNATIONAL 4900 CAR HAULER (A59575)
2000 INTERNATIONAL...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
