zmansmac
Gold Member
This summer I bought a new snow plow, just the blade, and had to build an A frame and adapted the cross bar from my old plow to attach it to my loader arms. I welded the cross bar at the base of the A frame so the mount would similar to the way it connects on a truck, just like my old plow. This new plow is a little wider, taller and weighs about 3 times more than the old plow. The additional weight became more apparent the first time I lifted it attached to the loader arms. And because of the dual cylinder angle (single on my old plow) it ended up being a bit further out in front of the tractor. I knew this would not be a problem pushing snow with it straight but I was worried that when angled it would have much more of a tendency to move the front end of the tractor over. And then I read the recent thread about someone asking about adapting a truck snow plow to a quick attach. I saw 4shorts answer and his pictures and realized his solution was something I never thought about and was the best answer to my concern. And being a member of this forum for many years I've seen other projects of 4shorts and know that he has great, well thought out designs. I do wonder if he ever actually uses his tractor because all of his project pictures show a clean machine that looks brand new. But this is a perfect example of what makes these forums so great - sharing information. Because I had to shift the loader arm connection point slightly I made a new cross bar for the plow. And I know how much everybody enjoys looking at pictures so below is an "after" and "before" picture of my new plow setup.
