Snowplow design with float & d/p.
   / Snowplow design with float & d/p. #1
Rustyiron
Super Member
Lakes Region, Maine
M 9540 Kubota
I've been making converted p/u truck snowplows for tractors & SS's for a while using this design that allows for float (normal) action along with down pressure. Notice the tube in tube with the welded stops on what could be called the "top link". If you can't see in the pics, you curl in the bucket function so that it hit's the stops and raise's the plow, and "dump" until you hit the stops for d/p.
On this particular plow I gave it 12" of plow motion before it hit either of the stops. You position the frame (bucket curl out) to a mid point between the stops, ( 3" each way to the stops) giving you 6" of travel down, and 6" up. You need to provide a pivot point at each end of this tube for the slight movement through it's arc, and it need's to be rugged. The geometry on this plow/frame worked out that each inch of travel on the diag. tube gave 2" of plow movement. The tube is 2x2x.25 wall, and the rectangular tube(s) at the loader are 2x3x.25 wall. Thought it might help someone.
   / Snowplow design with float & d/p. #2
Good idea... probably works great.. Would like to find a reasonable priced plow to do it.. Thanks...
   / Snowplow design with float & d/p. #3
Really like this, nice job fellow Mainer.
   / Snowplow design with float & d/p. #4
Nice design Rusty. I've been planning for the same end result with my plow but a different way of doing it. Never thought of your way.
   / Snowplow design with float & d/p. #5
That is a very good idea and well done.
   / Snowplow design with float & d/p. #6
Nice. One note, several people on here have had success with placing their pivot points ahead of the mounting points for the angle cylinders (so the blade is tucked in closer to the loader).
Less force on the front axle that way (because the blade is closer to the axle) and a little less risk of bending the loader frame.
Aaron Z
Aaron Z
Yes, I've seen them, very cleverly done!
I asked this guy if he was concerned about that, and he was not. It adds a lot ot time to the build (rebuilding the blade) this version is only about a half day job with only minor modifications to the plow it self. This design started out for me & 3 buddies with skid steers that had snow plows, and works fine in that application with the plow mounting only about 12" ahead of the front wheels. With the advant of tractors with ssqa in recent years……. . I think "snugging" up the blade for a tractor, esp. smaller one's is worth the effort for the sake of the tractor, loader, and performance. Frame mounting would be give the best results but most do not want to loose the higher stacking ability of loader mounting.
   / Snowplow design with float & d/p. #8
Makes sense for a skidsteer. A lot of skidsteers wouldn't have the room to tuck the back of the A frame in without it hitting the frame of the skidsteer.
Aaron Z
   / Snowplow design with float & d/p. #9
Sweet. Sounds like you've got the design all worked out for when I commission you to do mine ;-).
ac
   / Snowplow design with float & d/p. #10
Cool design. My current setup is a quick hitch welded to a SSQA plate. The cross piece I added to the back of my cheap manual plow fits into the hooks on the which hitch. Chain goes to the toplink hook.
I'm on the lookout for the right cheap hydraulic angled plow for my next one. Probably find it during the summer. Will definitely come back and eye up your design again when I get to the new build. I do want to make my next one a more compact design though like others have noted. My current design was easy & works well, but could be improved a fair bit (hydraulic angle, your diwnpressure thing, more compact, etc.)
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
Approximately 10 Sheets of 9ft Tin (A57454)
Approximately 10...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
CFG Industry QK18R Mini Excavator (A57149)
CFG Industry QK18R...
INOP Arctic Cat 650 Four Wheeler (A57453)
INOP Arctic Cat...
