pontio pilato
hello.am trying to build a DIY ripper attatchment to break up virgin land.i intend to use it with a MF385 4WD tractor(milat).the lower links seem somewhat weak for the job,so i am thinking of attatching the ripper to the rear axles using an articulated joint.is this safe,from a point of view of it might damage the tractor?how far apart are the best attatchment points?also,how high from the ground is the PTO?all help will be appreciated and acknowledged.thank you.
