mrtwister
Hello to all!!
I'm building roller toe boards for my sawmill much like the one pictured below.....they are used to raise the small end of a log so the log-center/pith at both ends of the log are an equal distance from the mill bunks which ensures a proper first cut.....my plan is to build the actual roller from 2" gas pipe. My dilemma is that I'm not sure how to incorporate bearings and a shaft to complete the roller itself....I've done multiple searches on the net for ideas but could not find anything to match what I need to do. Can a bearing be inserted into each end then spot welded to secure it before inserting a shaft or will the heat damage the bearing? (assuming I could find a bearing that would fit inside the end of the pipe).....or is there another easier or more efficient way to build this thing?
Does anyone have any ideas or experience building rollers like this?.....any input is appreciated....thank you.....Twister
