Osu98
First off thank you for any help I can get here. I'm going to start a corral building project and looking for any advice I can get. It's a big enough project without having to reinvent the wheel.
I'm thinking about using 4.5" posts on the gate posts and the gates are weld on made out of 1.5" tubing. I would like to make a few where they swing basically 360 degrees but I know the hinges have to be offset some to make that happen. Have any of you done this? What is the easiest way to make it happen?
Also is it necessary to use 4.5" pipe for the gate posts or just run the 2 3/8 up and over to brace them? We will have some goats in the future so my plan is to use 2 3/8 on a top, middle and bottom rail and weld cattle panels to it. Any better ideas? I think the 4.5" posts will be a little more expensive but easier to work with instead of having to weld a cross piece 10' off the ground.
