Results 1 to 3 of 3
  1. #1
    Join Date
    Dec 2012
    Posts
    67
    Pawnee, OK
    JD 3020 Propane
    Default 2" receiver tube on draw bar
    I needed a couple extra inches on my hitch to accommodate my drag style brush hog. Instead of cutting down the pto shaft I decided to lengthen the draw bar. On the longest position, it was just inches too short. I came up with welding a receiver tube to the draw bar. This now accepts all my standard ball mounts that I have and will provide the extra few inches that I need. This may not be the ideal solution for dragging a heavy plow but that is not really in my things to do with this old tractor. This is just a 2.5x2.5 tube with 3/16 wall. I welded some 1' x 3/16 straps over the tube for additional support.
  2. #2
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    7,983
    Central Square, NY
    LS XR3037HC
    Default Re: 2" receiver tube on draw bar
    Looks good
  3. #3
    Join Date
    Nov 2007
    Posts
    677
    South Carolina
    That's cool.
    The draw bar on my tractor was missing when I bought it. I plan to make a draw bar with a 48" piece of receiver hitch.
    I'm mostly going to pull a chain harrow and hopefully a pull type bush hog.
    IHC 424 Diesel
    Ford 917 Flail Mower
Similar Threads
  1. Draw Bar Receiver Hitch
    By jwguthrie in forum Attachments
    Last Post: 04-30-2015, 08:25 AM
  2. Replies: 1
    Last Post: 04-28-2013, 08:35 AM
  3. Backhoe JD Hoe Subframe Part #LVA13818 "NEEDED" Cast Draw Bar Support!
    By magelan36 in forum Attachments
    Last Post: 04-27-2013, 05:55 PM
  4. Draw bar, receiver hitch attachment?
    By Turtro in forum Kubota Buying/Pricing
    Last Post: 05-05-2008, 04:59 PM
  5. DRAW BAR/RECEIVER HITCH
    By flINTLOCK in forum Attachments
    Last Post: 01-16-2007, 05:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
