tmajor
- Joined
- Oct 9, 2007
- Messages
- 704
- Location
- NE PA
- Tractor
- 2010 MF 1529, Woods ZTR MZ1952, National Mower sickle bar circa 1963
Hi y'all,
Well, last fall, I restored the NAA Jubilee.
This year, I was thinking about brush hogging the fields and knew that the hay seeds, etc. block the radiator fins, and come out the back like a sand blaster, if they get through. Plus, I put in a new radiator, which I'd guess is about half the radiator the original was.
So, I put a furnace filter over the radiator grill, before starting this years mowing. That , ... maybe worked for a while, but then the tractor started getting hot. I had shut off a couple of times and let the seeds fall off, but after quitting for the day, I pulled the filter off and it had a bunch of stuff behind it! :thumbdown:
Then, I was picturing the off road vehicles with the snorkels for carburetor air.
I started building an air scoop (not so much a "scoop") duct for the tractor, so that it's cooling air source was up out of the trash.
I fabricated 2 sides and 2 spreaders to fit against the radiator and behind the hinged grille. Then I covered the front with aluminum.
I made some J-bolts to go through the radiator holes and catch the back edge of the cowling, to hold all in place.
I mowed about an acre @90 degrees F. and the temp gauge finally made it into the red. Some of the hay/weeds were 4-6 inches higher than the duct. But, there was very little on the radiator, when I removed the duct. But, my "air window", at the top was smaller than I had planned, plus the front medallion stuck out. So, I'm going to make a couple pie shape "add-ons" to allow for a bigger air window. Below, is what was behind the duct, when I removed it. I placed a tarp on the ground, before shutting off and next to nothing dropped down. :thumbsup:
If it were painted Ford Gray, nobody would notice .... would they?
