NCShelton
Can any of you do-it-yourselfers out there make up the lift arms similar to those shown on the web go to the site & click on 3 point hitches: [image]http://www.ernies.net/[/image]
I bought a set to go on my Yanmar YM2000, and the arms are too short. The fabricator used a standard length arm and bent an offset, but started the offset too soon, and it will not clear the 9.5x24 tires. And, with the offsets, it is 4" shorter than it was, making it too short. What is really needed is to use an arm 4-5" longer, start the 45 degree offset bend toward the outside of the tractor 18.5" from the connection on the tractor, continue the offset until it is 4" further to the outside of the tractor, and then offset 45 degrees back toward the center of the tractor. The finished arm needs to be 28.5" to 29" from connection on the tractor to the end connection of the lift arm. Holes needed in the lift arm for lift link and sway chains are 8.5" c/c from the connection on the tractor, then 3.5" to another, and then 3.5" to another. The hitch pin clip shown on the photos would be a nice adder too.
I suggested these dimensions to the vendor, and he did not seem interested in making the lift arms I have described. The ones he does sell will not fit a YM1700 and larger Yanmar, although his website says they will.
Would any of you be interested in making a pair of the arms for some of us Yanmar owners? I really only need the lift arms, but if you made a complete set, with sway chains instead of the turnbucle sway adjusters, I'd take the set. Not interested in a set with turnbuckles, though. They do not allow free swinging like chains do.
Any takers?
Norwood Shelton
Control Systems Engineer, Retired
Monroe, LA
Yanmar 2000
64 Ford F100 (my dad's, restored)
55 Ford Customline
Any takers?
Norwood Shelton
Monroe, LA
Yanmar 2000
55 Ford Customline
