300UGUY
Super Member
I am going to track this thread. Something I want to do myself.
You are welcome to borrow any ideas (heater, wipers, lights, etc) you can get from my cab build. I tried to list part numbers and prices as much as possible.
http://www.tractorbynet.com/forums/...-diy-cab-build-kubota-l4850dt.html?highlight=
..................................I also need some heavy rubber, 1/2" thick or better, to go between the tractor frame and the cab mounts so I'm not making an echo chamber.
The "fun" part tonight will be the door frame, which will be angle iron, which needs ot be cut to make a 90 degree bend in, then cut many times to curve around the fender. Have to do that for both sides, then again to make the actual door. Going to use screen door handle/latch for opening and closing...............................
