crazyal
Super Member
I'm thinking about making one of these (but much smaller).
I'm thinking of making two 18" wide spiked wheels. I figure I could use two pieces of 12" pipe with plates welded on each end with flange bearings on each end. Each one would be articulating enough to make up for unevenness of the road. It will be 3pth hitch mounted so it'll have to have enough weight to break up the ice on the dirt driveway. It would look kind of like a harley rake but not powered and not the full width. What I haven't figured out is what to use for teeth. I would like find some that are threaded so they could be removed when they wear. Does anyone have any ideas?
Here's a look at a different brand. These are make for highway use by much heavier equipment moving at much faster speeds. This one just looks like you replace each wheel when they wear. One of the mfgs say they last 5 years but that seams overly optimistic unless they are harden steel.
Here's a youtube:
Here's a youtube:
