fitterski
Gold Member
- Joined
- Oct 20, 2016
- Messages
- 377
- Location
- Nouvelle, QC
- Tractor
- 1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
I'm planing a redo of my snow-blower (see also under hydraulics) and ONE possible Tx resolution would be to place the engine-and-transmission behind the 4x4 vehicle and find a way to pass a single driveshaft right through whatever is in the way between it and the snow-blower in the front. The snow-blower yoke height would depend on the impeller diameter and would likely be between 1-1/2 to 2-1/2 feet. The multiple driveshaft solution I'm addressing here would instead use a 1st driveshaft to get down under the frame and axles, a 2nd to get to the front of the vehicle, and a third to rise back up to the impeller yoke.
The 1st shaft going forward and down from the ackbassword engine/tranny would probably get below the frame at a point forward of the rear axle, the rpm would be in the lower range like 0-1100, torque shoulbe be below 2000 ft-lbs. I have very basic or rather only rudimentary driveline theory in my head, such as the ends of u-joints on both ends of one shaft should be parallel... and that's as far as I get
Any hints welcome
Any hints welcome
