ssrider
Member
- Joined
- May 8, 2014
- Messages
- 47
- Location
- East Selkirk, Manitoba
- Tractor
- 1963 massey 150, 1972 Dynahoe 190
Ever since I bought my tractor I have been meaning to build something to keep the 3ph attachment from swaying so much. I also wanted to be able to set my blade off to one side at times. Finally got around to it. Couple turn-buckles, some chain, and a couple bolts is all it took. Works great so far.
It looks like your 3 point will bind and not lift all the way up, because the stabilizer pivot point is not in line with the lift arm pivot point.
Note the white arrows at the pivot points:
It's actually the opposite. When I lift the 3 point all the way up, the arms gain a little slack. The chain on the ends of the turn-buckles allows for this and the slack is very minimal.---------------.
