Aussiebushman
Gold Member
- Joined
- Jul 31, 2008
- Messages
- 251
- Tractor
- Ford 6000
My Ford 6000 is named after my ex wife because it shares the qualities of being loud, aggressive and unpredictable.
I was adjusting one of the tire chains and because one shackle was under the tire, I decided to move the machine forward a foot or so. A supplementary starter switch next to the fuel pump makes it easier to prime the diesel pump and push the start button - works every time. Only one problem - it starts in gear and I lacked the brains to check first. The ground underneath slopes up slightly, so all is well with tractor in its usual position under the shed roof but several feet forward the cab catches on a rafter - thus demolishing the shed completely before I could stop the engine.
I finally got under the wreckage and started up again to back the machine out but, as noted, not being strong on brains failed to consider what might now be trapped under a wheel. You guessed it - a serious steel plate now standing vertically that went right through the side wall.
Scouring the Eastern states of Australia for a used (can't afford or justify a new 23.1.26 Ag tire at $1400 each) is like searching for Rocking Horse sh#t in a desert. Meanwhile. getting the wheel off and into a trailer to take to town is not for the faint-of heart but some tugging with a 4WD, innovative use of beams, jacks, chain-blocks etc gets there in the end.
Once another tire is fitted, the procedure must be reversed (well, not all of it I hope). A second tractor with a jib will do but if any forum members in the military with access to a helicopter here is OZ, please let me know.
Alan
Alan
