boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,824
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
remmington 8amp 2 in 1 saw. 10" blade
2 in 1 = pole comes off and you have a electrical chain saw.
couldn't pass it up menards on sale. and then 11% rebate to that picked it up for like $70 plus spare chain for it
Amazon.com : Remington RM1 25P Ranger 1 -Inch 8 Amp 2-in-1 Electric Chain Saw/Pole Saw Combo : Power Pole Saws : Patio, Lawn & Garden
cutting down trees. they are either to close to home, electrical wire going to street, sheds, LP tank, fence lines, etc... and wanting to trim out the tops of the trees before taking the main trunks out.
i am right at limit of about 15 feet with pole that comes with it. i have some branches that i could cut, but they are straight up vertically, and no real way standing on ground to cut the branches out. needing a way to mount chain saw 90 degrees? so i can stick up there and make my cuts, with a pull wire, to bring them down without them going into anything.
i may rent a man lift (not scissor lift) to finish things out on some trees. or higher the remaining portion out. but wanting to cut what ever i can myself. before i start renting or highering it out.
it has been a while cutting down trees. was thinking fishing pole and some weights on end of line to toss over tree, then pull cable on up. no bows, no sling shots. guessing around 50 to 60 feet max height tallest trees. any other suggestions for getting cable up on trees without climbing / without using a man lift?
to note it, i am NOT interested in a rope saw. or less i can hook up a motor to it.
